Omori EGT gauge in stock WRX gauge pod
Results 1 to 5 of 5
This is a discussion on Omori EGT gauge in stock WRX gauge pod within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Has anyone put an Omori EGT gauge in the stock WRX gauge pod? I plan to keep my Lamco boost ...
    Registered User Rich10's Avatar
    Oct 2002
    Long Island
    Has anyone put an Omori EGT gauge in the stock WRX gauge pod? I plan to keep my Lamco boost gauge and replace either the oil temp gauge or the voltage gauge with an Omori 45 mm EGT gauge. If you have done this, how does the single Omori gauge fit in with the other gauges? Any problems with this? How does the Omori EGT gauge look next to the Lamco gauges?
    2002 WRX WRB
    Banned dark_rex's Avatar
    Aug 2001
    The Hub
    Lightbulb
    do you mean the column mounted guage?
    Factory Boost Gauge
    Column Mounted Boost Gauge
    the omori matches your guage cluster exactly with the green lighting and red needle. it's even closer to the tach and speedo than the lamco.
    dR
    Oct 2002
    Long Island
    dr,
    Actually, I was referring to the Lamco gauges that replace the clock in the center of the dash. I would like to replace one of the Lamco gauges (either the volt or oil temp) with an Omori EGT gauge and was wondering if anyone did this and how it looked. Does the Omori gauge look very out of place next to the Lamco gauges?
    Anyone?
    2002 WRX WRB
    Registered User KanosWRX's Avatar
    Dec 2001
    Northern VA
    I don't think you will find a closer match then the omori gauages. and if I were you I would take out the volt and put in the egt, the oil temp can still be useful.
    My Mods
    "The most important mod is the one behind the steering wheel" - Koyokid RIP
    Oct 2002
    Long Island
    While oil temp is probably more useful than voltage, my oil temp gauge has failed on me twice. Since I will be off the warranty soon, I figure that I'd get rid of that one. Also, the only thing that the oil temp gauge tells me is that it takes the oil approx 5 minutes longer to warm up than the coolant.
    If I heard that the Omori gauge would look very out of place with the Lamco's, I'd just wait a while and replace all three. Also, I was wondering if there were any problems that came up in this installation that were unforseen?
    2002 WRX WRB
