Factory Boost Gauge
Results 1 to 9 of 9
This is a discussion on Factory Boost Gauge within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Hey i was just wondering if anyone has done this or not. I would like to put an aftermarket boost ...
    Registered User WrXtremeEJ20's Avatar
    May 2003
    Phoenixville, PA
    Factory Boost Gauge
    Hey i was just wondering if anyone has done this or not. I would like to put an aftermarket boost gauge in where the stock one is on the steering column. How hard do you think it is and how can it be done. I ripped apart one that i had at my work and it looks pretty weird then any other boost gauge that i have installed.
    Banned dark_rex's Avatar
    Aug 2001
    The Hub
    i have the column mounted gauge, and i'm installing another on the other side of the column for EGT.
    i believe it's a 43mm hood, but some say a 45mm gauge can be squeezed in there.
    i'm looking at usuing a 45mm Omori EGT, and possibly switching the boost to an Omoro 45mm at a later date.
    dR
    Banned hippy78's Avatar
    Jun 2003
    I have the omori gauges and they look/work nice. From what I know they won't fit in the stock pod.
    peace
    Aug 2001
    The Hub
    peace
    no, it'll fit. just takes a little wiggling.
    Column Mounted Boost Gauge
    check this one out. this is the omori guage in the stock housing (45mm)
    dR
    [moved to cockpit & cabin]
    Registered User Vostok 7's Avatar
    Dec 2002
    Limehatless Avatar - I'm a trend scoffer.
    I've got a 45mm Omori Electric boost gauge in the stock rubber cup. It's a heck of alot better than the factory Lameco, but 45mm Omori's are harder to find than icicles in Florida and 45mm, being bigger than the stock cup, is like squeezing Chris Farley into a speedo. It can be done, but it's not easy.
    I'm upgrading soon to a Defi 52mm unit though. Omori is the only gauge I've found that'll fit... Unfortunately, none of the really good manufactures (like Defi) make gauges that small.
    Vostok 7
    BUGEYE 4 LYFE! Or uh maybe not
    RIP Team Intrinsic Viva la Project 1! http://www.prjct1.com/
    2003 Subaru Impreza WRX Sedan 4EAT Aspen White "Akane"
    Mod List, Picts
    2004 Subaru Impreza WRX STi Sedan Aspen White "Akane II"
    Dec 2002
    Originally posted by dark_rex
    (that's my car BTW in an early incarnation )
    Vostok 7
    Mod List, Picts
    Registered User scrapy2's Avatar
    Mar 2003
    belleville,ill
    i got a quest. what about put a after market boost gage in but can you use the factory wiring .sorry for asking these in the middle of this thread but i want to do the same thing or maybemove to a pod on the left . thank you
    Dec 2002
    Can you use the factory wiring? Not totally. There's only two wires that go to the Lameco gauge because of Subaru's funky wiring system (the same reason aftermarket gauges won't dim). IIRC, when I wired up my Omori, I had to use part of that wire and some other to get everything I needed... but I can't totally remember. It's been some time since I installed my Omori gauge.
    As far as mounting the pod somewhere else, the '04s put the pod on the left hand side so it doesn't cover the speedo/odo. You certainly can do it, but it will leave you a couple holes on the right hand side (if you already have the gauge there).
    Here's the instructions for installing the stock pod and gauge...
    https://ssl.autocenter.net/webparts/acatalog/page1.html
    And here's the parts for the gauge kit...
    http://www.subaruparts.com/catalog/s...BoostGauge.jpg
    Hope that helps.
    Vostok 7
    Mod List, Picts
    Aug 2001
    The Hub
