is there a link with the speakers? price?
This is a discussion on Found some almost direct bolt in speakers within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Just wanted to let you all know about my findings. I did find a set of 6.5" speakers that fit ...
Just wanted to let you all know about my findings. I did find a set of 6.5" speakers that fit in the door of my 02 wrx wagon *almost* perfectly. I didn't even have to make a spacer because they came with their own. The bolt holes *almost* lined up perfectly, but I did have to drill 2 tiny tiny holes in my door and use the screws that were supplied with the speakers.
The speakers are clarion "SRR1626" 6.5" coaxial speakers. I did not take any pics during the process, but it went pretty smoothly. There was 2 approx 1/4" spacers/brackets, 2 speakers, and 2 thin metal mounting brackets I guess is what you would call them. I put the metal pieces on the back side of the speakers mounting flange, and then the plastic spacer on after that. I screwed the speaker into the spacer, then screwed the spacer into the door. Had to slightly drill out the holes in the thin metal spacer just a little bit so that the screw could go through it and into the plastic spacer.
So far they sound great, and there is no interference with the window at all. I may take the door back apart to take some pictures. Let me know if there is anything else that you want to know about it.
Aaron
'02 White WRX
Fan of Helix
I paid $79 at a local store, because they let me try fit them and what not before I bought them. I just found them for $59 on sounddomain.com The link is http://www.sounddomain.com/sku/CLASRR1626 They sound really good so far, and for $59 you can't really go wrong.
Aaron
'02 White WRX
