I'm wondering this question too.
This is a discussion on How to Get to Cigarette Lighter Wires within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I'd like to tap my cigarette lighter wires for power. Trouble is, I can't seem to get at them. Can ...
I'd like to tap my cigarette lighter wires for power. Trouble is, I can't seem to get at them.![]()
Can someone describe what needs to come off, and how to get it off? Pictures would be great if you've got 'em. I don't want to break anything by forcing panels.
Thanks!
02 WRX Sedan, Silver ("Bugeye")
TXS Up-pipe, Turbo-back w/cat, Cobb AccessECU Stage 2.
97 Legacy Outback, White
Stock. Very stock.
'03 white rex
1. Pull out drink holder.
2. remove two screws it was hiding.
3. pull out bezel around stereo/temp controls, just pull out from the top.
4. remove head unit (remove CDs first).
5. remove screws holding temperature controls.
6. slide/twist temperature controls upwards.
7. the wires are now exposed.
8. the plug leading from the harness to the lighter is mounted to a metal piece, just pull and twist it until it pops out.
or you could use quick-splices to tap into the wires where they are.
I did this when i spliced in a 3-port lighter adapter. i mounted it behind the glove box for semi-permanent things that need less than 12v (XM, GPS).
I got the idea from this mod:
Scoobymods - 12v
'03 Blue sedan.
Pretty much it.
Thanks! I was hoping it would be easier than that. I hate to go in and disconnect the head unit and HVAC controls just for this.(I love that smiley.)
Maybe I'll find a different power source. Fuse taps or something.
Just pull it all out. I didn't want to either. It's not that big of a deal. If i had to do it again it would only take 5-10 minutes.
I'm glad i did it because now i have no fear of dismantling my dash/console.
You don't need to disconnect the temperature stuff, just remove two screws and push the module up.
'03 Blue sedan.
Pretty much it.
