Results 1 to 7 of 7
This is a discussion on Seatbelt noise. Help! within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Whenever I pull on my seatbelt to put it on, the friction of the belt going through the loop makes ...
    Registered User Hah72215's Avatar
    Aug 2002
    Tempe, AZ
    Question Seatbelt noise. Help!
    Whenever I pull on my seatbelt to put it on, the friction of the belt going through the loop makes a really loud squeal. The passenger side doesn't do this. I was wondering if this is just from wear and tear or if there are any solutions. Any suggestions would be appreciated.
    "You have a sunburn, mmm, like chokolada, ahhh, it's you, me and Pina Colada."
    Registered User barosborough's Avatar
    Aug 2003
    Milwaukie OR
    Mine does the exact same thing! Bump
    2002 Aspen White:
    AVO Turbo-back, AVO TMIC, AVO BOV, AVO Short RAM Intake, AVO 15lb Wastegate Actuator, 225/45/17 Toyo Proxes 4 tires on 17x7 ADR wheels, SPO Front and Rear Sway bars, H&R Springs, STI Hoodscoop, STI Grill
    1983 Toyota Landcruiser FJ60 121,000 original miles
    Registered User FFWRX's Avatar
    Dec 2002
    Greenbrier, TN
    ditto btw its a 2003
    Nov 2003
    mine was like that too.. but eventually it went away... never really tried anything to cure it...i have an '02
    Registered User Mabf355's Avatar
    Sep 2003
    Suburban Philadelphia
    Bump - I have had my 04 WRX since april and it has been making the annoying sqeek on the drivers side belt since day 1! Phew, I am atleast glad im not the only one. If i had to guess....it is the roller inside the panel that the belt folds over to come out into the cabin....just a guess though.
    WRX - It's not a rocket. It's a guided missile.
    Registered User tarmac02's Avatar
    Oct 2003
    portland or
    me too try adjusting up and down made mine go away
    for awhile
    02 wrx stage 2
    Registered User KuMa15's Avatar
    Aug 2003
    Blacksburg, VA
    i have an 03 and everything is going fine with the belts. except i put those cheap pads on from ebay and now there all frayed up. its just those stupid windows that are doing the squeaking.
