in my previous experience, the weight of an amp will not affect the performance of the car at all. The setup I would opt for would be like a single ten being driven off two channels of a four channel amp. The other two channels would drinve the front speakers. If you want significantly better sound than factory, then a sub is critical. 6 inch speakers can deliver only so much before rattling the doors apart. Oh, BTW, invest in a little sound deading (dont need to cover every square inch), you'd be amazed at how much it helps...
LinkBack URL
About LinkBacks
