Installed Momo Shiftknob BUT...
Results 1 to 9 of 9
This is a discussion on Installed Momo Shiftknob BUT... within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I installed the Momo shiftknob that matches so well with the WRX but now my shiftboot just hangs loose. Before ...
    Registered User JimDab's Avatar
    Anaheim, CA
    I installed the Momo shiftknob that matches so well with the WRX but now my shiftboot just hangs loose. Before it was sort of connected to the shiftknob but now it sort of is just sitting there and doesn't look as professional as the stock look was. Is there any way to fix this short of wrapping duct tape around the metal part of the shifter to thicken it or something.
    2003 WRBlue Pearl Subaru Impreza WRX Sedan
    For Go: APEX'i AVC-R, Godspeed Uppipe, Samco IC Hoses
    For Show: JUN Eyelids, Clear Side-Markers, Momo RaceAir Shift Knob
    For Handling: Eibach Pro-Kit Springs, Cusco Rear Sway Bar
    Registered User AjIsDope's Avatar
    Aug 2002
    SoCal
    You could buy the small piece that holds it up, or your could use a rubber band.
    03 Cobra
    566whp/515wtq
    Pics
    & Dyno
    Pics
    Registered User doniguan's Avatar
    Aug 2003
    Elmira, NY
    wrap the shaft of the shifter rod with electric tape. Then put a little piece of double stick tape around it- automotive grade, either a pinkish red or black. Then jimmy the old boot up over it and it should stick. Thats what i did.
    Did you know that it is anatomically impossible to lick your elbow? And that 75% of the people who read that, try it.
    Registered User HiFiWRX's Avatar
    Nov 2002
    Bakersfield, CA
    Thumbs up Search Nasioc for "Paulie momo adapter"
    It not only makes the knob fit tight on the shifter so the screws NEVER come loose but you can also use your stock shift knob and it is as good or better than it fits on the OEM knob!!
    BIG thumbs up to "Paulie" for designing this adapter!
    http://forums.nasioc.com/forums/show...hreadid=393504
    In cause you don't want to search
    Anaheim, CA
    thanks for the tips
    ill probably try the electric tape method since i really dont want to bother too much with it. im almost happy enough with it hanging loose but i might as well try to fix it with what i have handy
    if it doesnt work out ill look into the piece Paulie made, hopefully it doesnt cost much to have sent over
    Apr 2003
    Northern California
    i bought a rubber washer from home depot.. something like 3/99 cents. I could look if i have the other 2 and send you one. it works perfectly and holds up the boot.
    Moderator smorris's Avatar
    Mar 2002
    Avon, Ohio
    I left the aluminum screw-on ring off of the bottom, and shoved the boot right up under the knob. It has stayed tight since last winter, and rides up a bit higher than the other suggestions, instead of hanging in the console.
    Take a look at a photo on the web page in my sig, or in the "Pics of your shift knob" thread.
    Steve - Avon, Ohio, USA - Moderator - Fun Drives and North Central States
    Explore the USA
    2016 Toyota 4Runner__2008 Outback 2.5XT Ltd (sold) __2002 WRX Wagon (sold) __ 1958 MGA Roadster __ and a few scooters...
    Registered User PKer's Avatar
    at work
    I have used the several rubberband technique with much success
    BTW: AJ, don't tell me you got a free Momo knob too!
    Registered User WRX-games's Avatar
    Oct 2003
    Arvada, CO
    Originally posted by smorris
    I left the aluminum screw-on ring off of the bottom, and shoved the boot right up under the knob...
    Yep! This is what I did. Looks factory and holds very well.
    James
    "Never criticize a man until you've walked a mile in his shoes. That way, if he doesn't like what you have to say, it'll be OK because you'll be a mile away and you'll have his shoes."
