Results 1 to 4 of 4
This is a discussion on Autometer bezel +OEM pod within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; (Cut and pasted from my post on Nasioc) Omori 2002 Impreza WRX Look Gauges -52 mm Electrical EGT in Autometer ...
    Registered User wrxlarc's Avatar
    May 2002
    Santa Ana, CA
    -52 mm Electrical EGT in Autometer Bezel
    -52 mm Electrical Oil Pressure in Autometer Bezel
    -45 mm Mechanical Boost in OEM Pod
    NOTES: The bezel was somewhat of a pain to get in there with the OEM pod in the way. I did use the 2 brackets that came with the bezel, they worked fine. The OEM screws that go in the top of the bezel were replaced by 2 #10 screws because I replaced the clips that they screw into... I lost one of the originals when I took the OEM pod out. The clips were found at the local autoparts place and worked great. Finally I sanded up the pod a little and sprayed semi-gloss black over it.
    The EGT is not plugged in yet, need the manifold tapped.
    And yes the guages in the pod are slightly tilted to the left, heh heh, I'll have to reset them one of these days...
    Close up
    Driver View
    Outside driver window
    Passenger View
    '02 GDA :: Platinum Silver :: 5 Speed : : Mods
    '97 4Runner 3RZFE 5spd 2wd grocery getter - slow, steady, dependable
    '12 Subaru Impreza Sport Limited
    Registered User Ludecrous's Avatar
    May 2003
    manchester
    I hope those gauges have memory or hold on them or you will go crosseyed !!
    Registered User Mat_Drinks's Avatar
    Aug 2003
    As someone with a new WRX trying to figure out how many gauges I want to add and where to add them I must say I like your set up.
    I like the TT mounting too, first time I've seen that... may have to use it myself.
    How do I shot web?
    Registered User FFWRX's Avatar
    Dec 2002
    Greenbrier, TN
    Does it rub when you move the steering wheel up or down?
