autometer boost guage
Results 1 to 10 of 10
This is a discussion on autometer boost guage within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I heard that they are always off by 1 to 2 psi. Is this true or what?...
    Dec 2001
    McLean, VA
    Moderator Penguinking's Avatar
    Nov 2001
    Houston, TX / Athens, GA -at the same time!
    good question.
    mine seems to be off by about 1-2 psi. when it shows 14 i think im actually running 15 or more. oh well... at least its consistent
    Dec 2001
    McLean, VA
    That sucks I just purchased one.
    Nov 2001
    don't worry. they're still good gauges. but you do get what you pay for. autometers cost 50, while greddys and defi guages cost some 200-300 per gauge.
    Oct 2001
    Tristates
    I heard that if you use a regular hose (using a 1/8 npt adapter on the
    gauge) instead of the tiny nylon hose, the gauge works better. I
    found this on i-club thread awhile back. They claim the small nylon
    hose does not let enough boost to hit the gauge. Make sense since
    the FBC uses 3 restrictors to regulate the boost and bleeds.
    I did plenty research before I got my rex and started the mods
    What mods, dude this baby is stock
    2002 Platinum Silver 5spd sedan.
    Jan 2002
    Elgin, Illinois
    I got one and nothings off or wrong with it.
    "They came they saw they lost"
    02 Plat WRX:
    AutoMeter Boost Guage
    HKS SSQ bov
    Joe P MBC
    Blitz SUS Intake
    TurboXS Unichip on the way....
    Administrator BlazinWRX's Avatar
    Apr 2001
    Irvine, CA 92620
    mine seems to be pretty accurate. If your'e insecure about your boost then adjust your MBC on your friends' car who has a Greddy gauge or wahtever and then see if there's a difference.
    Tim
    Admin
    Registered User berto's Avatar
    May 2001
    Irvine
    Tim, you say that you have a oost controller in your signature. What is that? Where can I get one? J/K. you gotta fix that.
    Dec 2001
    McLean, VA
    I installed My autometer boost gauge this weekend. the installation was easy. I went to pep boys and manufactured the t connector of 1/4, 1/4 and 1/8. After the installation I notice that my boost gauge was off by 2 psi. I removed the 1/8 compressor nut and noticed that the compression sleeve or ferrule was pinching the 1/8 tube. replaced it with a new one and the gauge now reads the correct psi.
    Registered User AntMan's Avatar
    Jan 2002
    Melbourne Australia
    Drod,
    So what readings are you getting now from your gauge?
    Also where does your needle sit when the car is off?
    I've got an Aussie MY02 Wagon. I get the following:
    Car off 1Hg Vaccum ie needle to left of 0 box.
    Idle 19-20Hg Vacuum
    Decel 24Hg Vacuum
    1st Gear 9psi going upto 12 at higher rpm
    2nd Gear 12-13psi
    3rd 12-13psi
    4th 12-13psi
    5th 15peak down to 12-13 psi.
    Cheers
    Antony
