Strobe light install
Results 1 to 15 of 19
This is a discussion on Strobe light install within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I want to install strobes at the bottum under the front grill . I never done this before does anyone ...
    Registered User plasteredcat's Avatar
    Sep 2003
    Baltimore
    Post Strobe light install
    I want to install strobes at the bottum under the front grill . I never done this before does anyone have step be step with pictures.
    Alex
    2004 Aspen White STI
    Apr 2003
    Hehe, I always wanted to buy some police strobes and put them behind the grill and then scare the **** out of idiots when they do a flyby.
    Sep 2003
    Baltimore
    Strobes
    I picked up one set Purple and one set white . Should look great .
    Alex
    Registered User Flex's Avatar
    Aug 2002
    I can see where you're coming from, but if Im not mistaken, its a felony to have them installed on a street car.
    Apr 2003
    Yeah, it is. Also would probably be charged with impersonation of an authority figure.
    tan
    tan is offline
    Thinking Man's Engine tan's Avatar
    Dec 2001
    Wharton, NJ
    You basically wire it into a on-off switch.
    Actually...it's more like wire it to an automotive relay.
    there are 4 pins:
    -Constant voltage (hooks up to the battery, with a fuse, probably a 10 amp should be fine)
    -Ground
    -Switch
    -to the strobes.
    Sep 2003
    Baltimore
    Strobes
    The strobes have two wires. one is a positive and of cousres one is negative.
    The switch I purchased has two pins .
    If i wire the a 10 fused wire to the positive side to the switch and then to the light can I just wire the negative some were else in the engine bay ?
    Alex
    tan
    tan is offline
    Dec 2001
    Wharton, NJ
    basically.
    Using a relay, though a little more complex, assures full power when switched on.
    Sep 2003
    Baltimore
    strobes
    When i go to the parts store , will the part called a relay or a fuse switch?
    Alex
    Registered User dudical26's Avatar
    Jun 2003
    I am an EMT so I put strobed in for when i repond to calls.
    Here are some pics fomr the outside and the switch...If you want I can give more detail
    Jun 2003
    here is the switch
    Jun 2003
    from futher away
    Sep 2003
    Baltimore
    Strobes
    Thanks, have any wiring pics ?
    Alex
    Registered User RLsChMiDt's Avatar
    Dec 2002
    Cleveland, Ohio
    Re: Strobes
    Why do you constantly attach that image? Yes, it's great and all... but there's NO need to keep on attaching that same picture!
    -Ryan |Dub-Yuh Our Ex Ess Tee Eye| My Car
    Sep 2003
    Baltimore
    strobes
    didnt know that picture was a problem . ever time I see its enjoyable . How this one ?
    Alex
