I bought the center section that replaces the clock, but it doesnt have the front part where the gauges actually sit. Does anyone know if it will fit.
This is a discussion on insert in gauge pod??? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Will this fit into the gauge pod that goes where the clock is?...
It says it's din size, so you could look up what measurements a single din is and then you would know... I would prolly look around the technical section of crutchfiled.com to start looking for this info.
The factory dash thing is indeed DIN sized, I know this b/c ive seen several headunits installed in that pod. Youll want to remeber though that it wont fit larger gauges, aka 60s.
I created my avatar.
Thanks I just wanted a second opinion. I didnt know if people had to modify the center thing to take radios, or if it was already that size.
