Turbo Timer Problem
Results 1 to 6 of 6
This is a discussion on Turbo Timer Problem within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Installed my Blitz FATT today. Has power etc, but for some reason it wont count down. I set it for ...
    Banned Mili727's Avatar
    Jun 2002
    Ga
    Turbo Timer Problem
    Installed my Blitz FATT today. Has power etc, but for some reason it wont count down. I set it for 5 minutes and when I shut my car off it just goes red and says 0.00. I had a harness, installed it correctly etc. Anyone know what the problem can be?
    Aug 2003
    Orlando, FL
    Did you run the wire to the parking brake?
    Justin
    2003 Sonic Yellow
    NOT STOCK ANYMORE!!
    Registered User Chopaholix's Avatar
    Sep 2003
    Guasa, Guasa
    Re: Turbo Timer Problem
    I got the same one as you did, but how do I install it??? I got the harness to.
    Hecho En Mexico
    Jun 2002
    Ga
    Yes.
    Registered User AjIsDope's Avatar
    Aug 2002
    SoCal
    Did you cut the green wire under the drivers side of the dash?
    03 Cobra
    566whp/515wtq
    Pics
    & Dyno
    Pics
    Registered User WRXin''s Avatar
    Jun 2002
    Houston, TX
    Okay Jon, you just solved two problems in one hit. You say your brake light flickers on, and that the TT isn't working right eventhough it's tapped into the e-brake wire. Check that wire from start to finish. I'm almost certain now that this is your problem
    Fahd
    Floats like a butterfly and stings like when I pee!
