60mm Gauge pod that doesn't look stupid - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 46
This is a discussion on 60mm Gauge pod that doesn't look stupid within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; How many gauges are you looking to install? I only wanted one, so I got the SubieGal single 60mm Dash/A-Pillar ...
    Moderator smorris's Avatar
    Mar 2002
    Avon, Ohio
    I only wanted one, so I got the SubieGal single 60mm Dash/A-Pillar pod. It finally arrived Tuesday (long story - 10 month delay...) and I ordered a 60mm Omori WRX-look boost gauge from Gruppe-S. It should be here tomorrow.
    It mounts in the corner on the dash against the pillar. Anyway, here's the pod just setting in the car. I'll add pics as I install it.
    http://www.morrisgarage.com/wrx/pod/
    Click on any image for a larger size photo.
    HTH,
    Steve
    Steve - Avon, Ohio, USA - Moderator - Fun Drives and North Central States
    Explore the USA
    2016 Toyota 4Runner__2008 Outback 2.5XT Ltd (sold) __2002 WRX Wagon (sold) __ 1958 MGA Roadster __ and a few scooters...
    Apr 2003
    I'm not really a fan of A-pillar.
    I would use the oem pod if I could find someplace that carries wrx-look omori gauges that are 45mm or 52mm
    I'm gunna get EGT, oil press, oil temp. And if I have the extra cash I might get a 45mm boost gauge and replace it with my oem one ( I can't stand that the oem gauges don't match)
    60mm seems to be the only size any one carries, only reason I don't want 60mm is so my gauge pod doesn't look like this:
    Registered User WRXin''s Avatar
    Jun 2002
    Houston, TX
    Originally posted by Sihota
    Ok, forgive me for asking too many questions....
    ISnt wrx's EGT sensors in the upipe?, and if you get an after market pipe you would need to get a CEL fix because there is no sensor anymore, therefore your EGT Seonsor wouldnt work. Am I right or completly off?
    What mods do you have done?
    If you where to get a Defi 3 Pod what 2 guages other than BOOST would you get and why?
    Im am not hardcore so I dont know what gauges would be the most benificial.
    Thanks ahead of time.
    There's no need to appologize...I'm happy to help There is an EGT probe in the uppipe and about 95% of aftermarket uppipes have bungs for the probe. So there's no need for a CEL fix. That probe does read your EGTs for the ECU. One you get a UTEC, there's an EGT reading and I believe that's where it comes from. When you get an aftermarket EGT gauge, you'd usually tap it into the exhaust manifold.
    As for which other 2 gauges I'd get, that would have to be an EGT and an oil temp. Many people will tell you to get an oil pressure gauge, and that's fine too. There's sort of a debate as to which one will serve you better. I think, they'll both help. The reason I say oil temp is because that's what Dan (God) said, and I live by his words of wisdom
    As for my mods, after this weekend I'll be a full Turbo XS stage 4 plus an intake and BOV
    Let me know if there's anything else I can help you with
    Fahd
    Floats like a butterfly and stings like when I pee!
  5. #19
    Registered User BoostedBoxer's Avatar
    Mar 2003
    NOR*Cal
    I paid 670 shipped for mine from dan at godspeed. So it actually was an arm a leg AND an eye. My egt probe is in the exhaust manifold- my godspeed uppipe has a port for the factory egt probe so that wasn't a problem. I believe it was worth it because the gauges are very nice and easy to read and get lots of compliments.
    P.s. Fahd- you got any pics?
    My Car is 100% STOCK!
    Pics
    Originally posted by platano
    At 14???
    shoot , I'd hit it at current age, on roof of the car, with cousin driving , neighbor and town priest in the back seat, and that kid from "N.Korea" riding shotgun.
  6. #20
    Jun 2002
    Houston, TX
    Not at the moment, but I'll get you some this weekend
    Fahd
  7. #21
    Registered User Sihota's Avatar
    Dec 2002
    Vancouver Island, British Columbia
    Do you have a closer picture of the guages?
    thats the best setup I have seen so far.
    I would also like to see fahds setup if possible.
    Speed Is Money, How Fast Do You Want To Go?
    http://www.cardomain.com/member_page...page_id=412927
  8. #22
    Apr 2003
    I guess I'm the only one who doesn't like the defi pod. Too bad I'm not out to impress anyone but myself.
    I might call up gruppe-s and see if he can get them for me. (smaller size gauges)
  9. #23
    Deerfield Massachusetts
    Chunks:
    I agree with you it looks a little RICEY or BOY RACER. Not the way I want my Rex to look either.
    2007 urban gray STI. KTR Ecutek Re-Flash
  10. #24
    Registered User mourning_air's Avatar
    May 2003
    http://www.awdpirates.net
    I agree also
    You can get an oem look pod at http://www.wrxtra.com/
    -or-
    get an aftermarket single DIN cd player and use the second din to put your gauges in. http://www.egauges.com/vdo_agrp.asp?SName=Dash_Inserts
    I'm not sure about the size though...
    <Ryan>
    '00 Silverthorn Metallic 2.5 RS
    '04 San Remo Red WRX Wagon
  11. #25
    Apr 2003
    Originally posted by mourning_air
    I agree also
    -or-
    Yeah I was thinking about that as a doable option, thanks for the links!
  12. #26
    Dec 2002
    I agree also
    -or-
    I think those look great too, except for the gaps between the gauges and the pod.
    and they are a decent price!
  13. #27
    Mar 2003
    NOR*Cal
    here
    Pics
    At 14???
  14. #28
    Dec 2002
    here
    WOW, that looks amazing!
    I shal save to get those!
  15. #29
    May 2003
    <Ryan>
  16. #30
    Dec 2002
    More subtle...
    http://egauges.com/vdo_acce.asp?Subgroup=WRX_Dash
    thats the best guage pod I have seen yet.
    wicked, now the issue is what 2 guages other than boost to get.
