Subaru Security light flash.
Results 1 to 15 of 18
This is a discussion on Subaru Security light flash. within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Does anyone know if it is possible to stop the flash of the lighting circuit when you lock/unlock the subaru ...
    Moderator aussieinstlouis's Avatar
    Jun 2002
    S34 47.322 E138 29.131 (WGS84)
    Does anyone know if it is possible to stop the flash of the lighting circuit when you lock/unlock the subaru security system?
    I want the horn to chirp, but no flashing lights.
    Cheers,
    Andrew
    Registered User djrez4's Avatar
    Colorado
    I don't have the wiring diagram in front of me, but I would assume there's a wire that controls each (since you can turn off the horn but keep the lights flashing). Perhaps if you simply switched those two wires, and put it in "silent" mode, you'd have what you wanted?
    Deliberating enclaves of like-minded people are often a breeding ground for extreme movements - Cass Sunstein
    Oct 2003
    O.C.
    Funny. Mine chirps but doesn't flash. How do you make it flash?
    Aug 2003
    Orlando, FL
    Its in the stock manual...For mine, i have had it in valet mode and never knew why the lights werent flashing...then i read the book and found out that it was in valet mode and switched it back to normal. I believe you press and hold both buttons at one time but I know for sure its in the manual for the car.
    Justin
    2003 Sonic Yellow
    NOT STOCK ANYMORE!!
    Sep 2003
    Arlington, TX
    If your lights are flashing and you don't want them to, then you can put your alarm in valet mode. This is done by opening the drivers door only and holding down both buttons for more than 3 seconds (the indicator light will flash). If you want the light to flash then you have to do the above steps to disable valet mode.
    sinister
    Jun 2002
    okay - maybe I should be more specific.
    I want the security system to work, but no light flash.
    Valet mode disables the security system.
    Registered User the mike's Avatar
    Dec 2002
    Delran, NJ.
    ClubWRX to the rescue!! Somehow I managed to put my alarm into valet mode. Don't remember doing it, but I did. Couldn't figure out why the security light was flashing and was about to contact the dealer. I decided to check the best WRX site out there and got my answer. This site rocks!!!!
    Creeping up on creeping for a decade.
    Bugeye Mafia V2 #322
    Apr 2003
    Brownsville, TX
    yeah security light flashing means disabled or "valet mode" I learned that when I took my car to get insured and I told them it had a shock sensor and I was banging my car and alarm wouldn't sound.....so I was pissed and later found out it was valet mode hehe
    2003 Platinum Silver WRX
    Stock Gutted Uppipe
    Registered User F15DOC's Avatar
    Nov 2003
    OK, so how many modes are there?
    Mine wasnt doing anything except the cockpit lights came on when activating the alarm.
    I just did the "door open, depress both buttons x 3 second" procedure and now the car beeps once for lock and twice for unlock?
    What are the "flashing lights"? Outside lights?
    Can you set it to beep and flash the lights?
    And, why is the security light blinking whether it is locked or unlocked??
    Roger L
    F15DOC
    2003 WRX - Sold
    1995 3000GT VR4 Spyder
    199 Mercedes Benz CLK430
    http://gemini.tntech.edu/~trthompson21/SPYDER3.GIF
    Registered User GotRice7169's Avatar
    Jun 2003
    Tampa Florida
    the lights they are talking about, i beleive, are the turn signals flashing when yu lock/unlock the car. Valet mode and turning off the chirp are different. Yu can have both the chirp and lights at once, or nothing at once. The back of the keypad should have the instructions for turning on/off the chirp, and like they said, the manual has the instructions for valet mode
    Nov 2003
    Strange, I got the horn chirp activated but still no light flash.... researching this now...
    Roger L
    F15DOC
    2003 WRX - Sold
    Nov 2003
    Got it,
    Although I got the audible chirp working, it was still in valet mode with the flashing security light...
    Opened the door depressed ONLY the Unlock button x 2 seconds... that did it.
    Now it is out of valet mode, lights blink and horn chirps
    Nice setup for customizing just how you want the alarm to work.
    Roger L
    F15DOC
    2003 WRX - Sold
    Jun 2003
    Tampa Florida
    yeh, i wish they just gave yu a different style of chirp, instead of just really loud, or off. Beggers cant be choosers i guess
    Oct 2002
    Torrance
    the 04 models have this high pitch beep but the 02-03 have the horn.
    does the light work on the 04 also?
    NEW 03 WRX bought NOV 16th 2002
    classified as a LEMON =(
    NEW 04 WRX traded with 03 lemon
    AUGUST 31st 2003
    work for HONDA drives a SUBARU =p
    Registered User OhForRex's Avatar
    May 2003
    Seahawks Country
    everything works just fine on my 04.
    *knocks on wood*
    ***2004 WRB WRX/Stocker than stocks***
