weird noise coming from shifter
Results 1 to 5 of 5
This is a discussion on weird noise coming from shifter within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I just installed my kartboy shifter bushings, they've made a nice improvement in the feel of the short shifter now. ...
    Registered User jungdragon's Avatar
    Jul 2003
    socal
    I just installed my kartboy shifter bushings, they've made a nice improvement in the feel of the short shifter now. Everything seemed to go fine during the install, but when I took it for a drive I noticed a faint whirring sound that must be coming from around the shifter, but I'm not sure how it was caused exactly.
    the noise usually comes in third fourth and fifth gear when i'm slowing down. A bit hint to me is that once I clutch in, it immediately stops
    03 wrx
    karboy ss/bushings, blitz dtt, catless, prodrive axleback
    Apr 2003
    CT
    Its just more NVH (noise,vibration, and harshness) from the stiffer bushings going into the shifter. Try hold it with your hand after you shift, and see if it goes away.
    '12 WRB Sedan
    Jul 2003
    socal
    I've tried holding the shifter but the noise doesn't go away. Would it be safe to use lithium-based grease on the bushings? I need some type of grease to try to remove the squeeking
    03 wrx
    Registered User SilverBugeye's Avatar
    May 2003
    Mine has also done that since I installed it 4,000 miles ago. The sound doesnt go away. If while in 3rd gear and like 3,000 RPM you put something on top of the shifter like, your cell phone , a ring, or anything metal or plastic you will see how much it is really vibrating... its crazy
    Sep 2003
    Canada
    The OEM shifter has a plastic (or something like that) ball at the bottom to reduce vibration. The Kartboy has a metal ball. You just have to get used to the extra noise.
