Results 1 to 10 of 10
This is a discussion on Melted plugs! within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Two weeks ago my left headlight plug melted So I went to the auto parts and bought me a 9007 ...
    Registered User ManguWRX's Avatar
    Nov 2002
    Raleigh, NC
    Angry Melted plugs!
    So I went to the auto parts and bought me a 9007 plug and replaced it. Yesterday I was doing the Koji Headlight modd and Noticed that the Right hand Plug its on its way also. Anyone also have this problem? I have normal bulbs. Why is this happening. Its sucks that I have a 03 (new car) with both harness replaced.
    Aspen White 2003 WRX
    COBB STG 2
    SQC #076
    Banned dark_rex's Avatar
    Aug 2001
    The Hub
    when you switched to non OE bulbs, did you check the wattage?
    Nov 2002
    Raleigh, NC
    I have Standard bulds .. they arent those Hyper white or whatever they are called.
    COBB STG 2
    SQC #076
    Aug 2001
    The Hub
    right... but did you check to see if the wattage was the same as the stock bulbs
    your replacement "standard" bulbs are most likely drawing more power than the stockers, and are therefore creating too much heat for the harness.
    dR
    Registered User GTIWRX's Avatar
    Mar 2002
    Conshohocken,PA
    this is right..check that wattage! the same thing happened to me and i ended up totally screwing up one of my harnesses
    Nov 2002
    Raleigh, NC
    Thanx guys! what wattage should they be?
    Now Im gonna go replace the other side.. damm that sucks the quality of after market plugs suck. Compare to Subaru
    COBB STG 2
    SQC #076
    Registered User Dick Fitzwell's Avatar
    Nov 2002
    moore,ok
    bump
    where did you buy the plug? can't find an autoparts store around that carrys one...help!
    tan
    tan is offline
    Thinking Man's Engine tan's Avatar
    Dec 2001
    Wharton, NJ
    The junkyard is a great place to go.
    9004 and 9007 are the same connector.
    Check the dealership to see if they have 9004 or 9007 repair kits.
    Nov 2002
    Raleigh, NC
    Originally posted by **** Fitzwell
    bump
    Pepboys or AutoZone.
    Tan the dealer only sells the complete harness.. Mega $$$$
    COBB STG 2
    SQC #076
    Nov 2002
    moore,ok
    good to know...thx
    true, called them already $600 and change!
    called both these jackasses and oreilly's as well...no luck
    thx for the replys though, after doing some research, i think im just going to order a heavy duty harness. my luck if i just replaced the one, the other would go that next week
