bump
This is a discussion on Gauge pod for CD player? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I wanna put my CD player in the place where the stock gauge pod is...you know in place of the ...
I wanna put my CD player in the place where the stock gauge pod is...you know in place of the clock. Can I just buy the stock gauge pod and fit the CD player there, or will I have to custom build a housing?
Fahd
Floats like a butterfly and stings like when I pee!
bump
Fahd
The gauge pod is single DIN size. The 6 CD changer fits in a 2 DIN spot I believe. Not sure about the single CD, though.
03 Subaru WRX Sonic Yellow
"The Short Bus"
Looks like ****, Goes like stink.
im pretty sure he means an aftermarket unit.
You are correct sirOriginally posted by Anarchy
im pretty sure he means an aftermarket unit.So that would fit then, right?
Fahd
it looks like it would but i cant be sure as i havent ever done it. u want a fast answer e-mail the guy that sells the LCD thing on ebay and tell him ur planning on buying one but u need to know how to install the cd player up there.
edit: his screen name on here is mattjk just pm him or something.
Many thanksOriginally posted by Anarchy
edit: his screen name on here is mattjk just pm him or something.![]()
Fahd
it will absolutely work. i did it in my '04 WRX. i liked the location, easy to read, all that. problems include difficulty reading the display in bright sunlight, and everyone (and his mother) seeing exactly what kind of radio you have, since it's above window sill level and on display for the world to see while you're driving. install isn't hard - you have to buy the gauge pack mount kit which can be found from $50-80 and will allow the mount.
s e t h"If you're going to live on the cutting edge, you'd better be prepared to bleed a little."Stink-Eye Mob #73, Hawkeye Alliance #667
Thanks for the mini review SethOriginally posted by Lightning
it will absolutely work. i did it in my '04 WRX. i liked the location, easy to read, all that. problems include difficulty reading the display in bright sunlight, and everyone (and his mother) seeing exactly what kind of radio you have, since it's above window sill level and on display for the world to see while you're driving. install isn't hard - you have to buy the gauge pack mount kit which can be found from $50-80 and will allow the mount.![]()
Fahd
