Autometer dual A pillar and grounding kit installed tonight
Results 1 to 15 of 18
This is a discussion on Autometer dual A pillar and grounding kit installed tonight within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; the Autometer dual A pillar gauge replaces the OEM guage. It fits perfectly!! the autometer boost gauge was amazingly easy ...
    Jul 2003
    KC, MO
    the autometer boost gauge was amazingly easy to install. I took the windshield liquid resivour out to get the boost line out.
    It reads instantaneously too so that's great!
    here are my readings (cool 70 degree night)
    intail start up: -10 vacuum
    1st gear: max PSI at 13 or so
    2nd gear: max PSI at 15
    no acceleration in gear: -15 vacuum
    does that sound right to you guys?
    oh I also got that light show Air fuel ratio gauge. I didn't know what to tap so it just sits there reading "RICH". any help here??!
    the grounding kit I got for 10 bucks and I really dont notice it doing anything for the car
    04 WRX Black no options!
    Helix up/downpipe, HKS catback & Bov, autometer gauges and MRT shortshifter, Bronze Rota SDRs, UTEC, tein SS coilovers, HKS type1 turbo timer, 6000K HIDs, JDM spec C front/rear lips, 20% tint
    to be installed: Mines Spoiler
    Jul 2003
    KC, MO
    alright found my answer to the airfuel ratio question:
    just tap B17 per this diagram
    http://www.ravensblade-impreza.com/m...ng/wrxpin.html
    to get to the ecu use Cobb's instructions:
    http://www.cobbtuning.com/Removal-In...-AccessECU.pdf
    Here some keywords for future searchs by newbies:
    air fuel ratio install ecu diagram instructions help
    Apr 2003
    CT
    It installed perfectly
    people with the replacement autometer A pillar
    Did you do the autometer boost gauge fix on scoobymods?
    '12 WRB Sedan
    Registered User BoostedBoxer's Avatar
    Mar 2003
    NOR*Cal
    i did the scooby mods gauge fix and it works like a charm. Also, my vaccum is at like -18 on idle, 13.5 boost (peak, stock) and like -21 on decel
    My Car is 100% STOCK!
    Pics
    Originally posted by platano
    At 14???
    shoot , I'd hit it at current age, on roof of the car, with cousin driving , neighbor and town priest in the back seat, and that kid from "N.Korea" riding shotgun.
    Jul 2003
    KC, MO
    hah you got me. Well it fits perfectly, but nothing to hold it in place!
    Jul 2003
    KC, MO
    hmm boost guage fix?
    mine goes:
    vacuum hose then the 3/8 inch hard hose then the gauge. My guage moves as fast as his movie so I think i'm good there. thanks for the tip though!!
    Jul 2003
    CO
    Is it worth running a A/F guage off of the stock pins and not using a wideband O2 sensor?
    Explain.
    Jul 2003
    KC, MO
    no the airfuel is not worth it, it is only a 1volt reading so it fluctuates so much it is pretty worthless, but I didn't have anythign else to put on there
    Jul 2003
    KC, MO
    damn it I think the back of my boost gauge is leaking.
    I hear a whooosh sound behind the boost gauge when I'm at max psi. I seem to keep it at 15psi till 6k rpms, but that whoosh sound is weird.
    My connection is BOV tube -> 1/4x1/4x1/8 connectore -> 1/8 vacuum tube -> some small hard wire -> boost gauge. I'm gonna try tightening the back of the boost gauge tommorrow.
    Apr 2003
    CT
    Add a hose clamp to that equation and youll be all set!
    http://www.scoobymods.com/forums/sho...oost+gauge+fix
    '12 WRB Sedan
    Jul 2003
    CO
    For the Dual A-pillar pod, what did you use to close the gap between the pod and the window? I have a good space between the two and it looks really ghetto!
    Apr 2003
    CT
    3M double sided foam tape should help you out.
    '12 WRB Sedan
    Jul 2003
    CO
    Do you have a part number, store name, or know the width and thickness?
    Apr 2003
    CT
    lol, any kind will do my good man
    Its usually found in the paint/trim section of any parts store.
    AFAIK home depot, lowes, carries it also.
    Its just tape
    '12 WRB Sedan
    Jul 2003
    CO
    Its just tape
    Cool. I was just wondering because the gap is HUGE. There is only one metal braket that I could put regular double sided tape but that is exactly what pulls it away from the glass. I will try putting the double sided foam tape on the glass side/underside of pod and then will just look for something to put on the outside of the pod and part of the glass to give it a sealed look.
