desperately need help with kartboy shifter
Results 1 to 6 of 6
This is a discussion on desperately need help with kartboy shifter within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; i just attempted to install the kartboy short shifter in my car. The stock shifter came out easily but I've ...
    Registered User jungdragon's Avatar
    Jul 2003
    socal
    Thumbs down desperately need help with kartboy shifter
    i just attempted to install the kartboy short shifter in my car. The stock shifter came out easily but I've been unable to get the kartboy into the socket. I've tried hammering it, as well as connecting the linkage and then pulling/pushing the shifter. I've heard of people having trouble putting the ball into the socket, but i had no idea it was this difficult. Can anybody explain exactly the method more pulling the shifter back into place when the linkage is attached?
    03 wrx
    karboy ss/bushings, blitz dtt, catless, prodrive axleback
    Registered User Teep's Avatar
    Feb 2003
    North Shore, MA
    since I just did this...
    assemble linkage with shifter in the correct position, make sure ball is greased and seated in the socket. pull back and push down, it should pop in. elbow grease helps (use a controlled forceful motion).
    you can do it... I did
    -tp
    here's the thread I read which helped
    MisterX's Avatar
    May 2002
    Prague, Czech Republic
    Put a piece of wood over the top of the lever and smack it with a hammer.
    I'm not kidding.
    X
    Jul 2003
    socal
    thanks for the help guys. turns out, i didn't really have a great hammer to do the job so i went out to get a rubber mallet which ended up working perfectly.
    Okay, now that i got it installed. Call me crazy but the rubber studs underneath the metal plate do not match up when you rotate the plate 180 degrees so i can't get the plate all the way flush with the rubber seal thing.
    03 wrx
    Feb 2003
    North Shore, MA
    I snipped 1 stub which was to the right of the shifter. The others on the top/bottom should fit into place. Of course I had to bend the metal tabs up to fit them in their new location.
    -tp
    Registered User mattjk's Avatar
    Mar 2002
    Huntington Beach, CA
