Grounding oil pressure sender
Results 1 to 4 of 4
This is a discussion on Grounding oil pressure sender within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I'd like to mount my oil pressure sender remotely, but I only have nylon tubing immediately available. If I used ...
    Registered User 04blkWRX's Avatar
    Jul 2003
    NNJ
    I'd like to mount my oil pressure sender remotely, but I only have nylon tubing immediately available. If I used that obviously the sender won't be grounded on the block but if I used a metal bracket to attach the sender to the chassis will the unit be properly grounded?
    Registered User PlatinumWRX's Avatar
    Jul 2001
    PA
    Re: Grounding oil pressure sender
    Should be fine, but you may want to run a ground wire for reliability.
    -Jim
    Jul 2003
    NNJ
    If I were to run an extra ground do I just solder it to the housing of the sender or something?
    Registered User jtgray_10's Avatar
    May 2002
    South Haven, MI
    Mine is mounted remotely, and attached to the block with the metal bracket and it works fine. Some senders (made for boats I believe) have an attachment for a ground wire, but mine didn't. Good luck, that install can be a PITA.
