What boost values should i be getting?
Results 1 to 5 of 5
This is a discussion on What boost values should i be getting? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Hi Folks, I'm concerned that my stock boost gauge (installed at dealer) is not reading correctly. I have been searching ...
    Registered User wrx666's Avatar
    Mar 2003
    A steamy bog in Raleigh, NC USA
    Hi Folks,
    I'm concerned that my stock boost gauge (installed at dealer) is not reading correctly. I have been searching (using terms like "stock boost gauge readings" and "turbo gauge readings") the board here, and it seems that most folks get a lot of boost w/ a little throttle input. I have to floor it (that's pedal hard on the floor, no partial) to get it anywhere near 0.1MPa. If i give it partial throttle, it will barely move to within 0.05MPa. I've read folks giving boost values at certain RPM's in certain gears, but mine doesn't seem to work like that. If i'm at 4K in 3rd gear i can be at 0.00MPa. If i give it a good bit of gas it will creep up, but it will not go anywhere near 0.1MPa unless i FLOOR it. Do these observations seem correct? Please show me the light. Thanks in advance.
    -JVS
    `03 WRX stock
    666 is just a number... sheesh!
    There's a lot to be said for keeping your mouth shut.
    Moderator aussieinstlouis's Avatar
    Jun 2002
    S34 47.322 E138 29.131 (WGS84)
    you will not get boost unless you are under load - which is mostly at WOT. You can get some boost at partial throttle.
    You are not seeing anything odd.
    What people refer to is how quickly the turbo spools once you plant your foot. Try in 3rd from about 2000rpm and you will see what people are talking about. The thing that you should be interested in is when you get to the highest boost value.
    Registered User JRod's Avatar
    Apr 2002
    Harrisonburg, VA
    The tubo will not produce positive pressure unless there is a load on the engine. If your cruising at part throttle on level ground while maintaining the same speed you should actually be in vacuum.
    In third gear while accelerating hard over 3000 rpms (stock turbo/ boost control) you should see just about 0.1 Mpa.
    But, if your at 4000 rpms in third gear (like you said) but not accelerating, it's normal to have 0.0 Mpa or vacuum (unless your on a hill or towing).
    edit: damn, aussieinstlouis beat me to it, I type too slow
    2002 WRX Sedan-Silver
    Turbo XS UTEC Stage IV (VF34)+TMIC, STI RA gears, Exedy clutch/flywheel
    Jun 2002
    Do you know why I pulled you over?
    No sir...
    You were typing at least 90 words per minute!
    Mar 2003
    Just a quick thanks to both of you for the quick replies. I feel better now. Well, at least i feel better about my gauge readings.
    -JVS
    `03 WRX stock
