OEM Boost Gauge Question
Results 1 to 4 of 4
This is a discussion on OEM Boost Gauge Question within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Hi guys, As the thread says, I had some questions regarding the OEM Boost Gauge. Is it mechanical or electric? ...
    Registered User FavreIsGod's Avatar
    Jan 2003
    Hartland, WI
    Hi guys,
    As the thread says, I had some questions regarding the OEM Boost Gauge. Is it mechanical or electric? I've been thinking of replacing it with an Omori 45mm gauge, to install this would I be able to simply switch the lines from the OEM to the Omori or would it be more complex? Thanks in advance, peace.
    Registered User Sick Boy's Avatar
    May 2003
    This should answer all your questions:
    http://www.j-spectuning.com/45mm_column.pdf
    Same place offers Omori 45mm mechanical boost gauges with the '02/'03 look, as well as the '04 look. http://www.j-spectuning.com/omori_rg.htm
    2004 Sedan Stage IV (w/ .5L envy) >>> Stripped & Sold!
    2007 Wagon Stock >>> Soon to be traded in for an 08 STI
    bambams247
    So the OEM boost gauge is a 45mm. Is it possible just to buy the pod and then get an aftermarket gauge? Is there a place that sells 45mm gauges? Something along the lines of Autometer Lunar series possibly? Let me know.
    Jan 2003
    Hartland, WI
    I don't really know of any other companies besides omori that sells 45mm gauges. Check out Sick Boy's link or go to http://www.omori-na.com for omori stuff. I'm sure you can pick up the pod somewhere. I'd check with a dealer or contact http://www.subaruwrxparts.com , I think they could help you out.
