Results 1 to 4 of 4
This is a discussion on Gauge Advice Please within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I purchased the oem gauge pod and two of the three gauges (boost & Volts) I do not have the ...
    London, Ontario
    Gauge Advice Please
    I purchased the oem gauge pod and two of the three gauges (boost & Volts) I do not have the oil pressure gauge for the third gauge. That was ok because I thought I would just install a clock in the third gauge spot. The problem is that I dont have the faceplate for the gauges. I thought I may be able to cut some holes through some abs plastic but now I see that the faceplate is actually gonna be a real pain to make. Im looking for any suggestion to mount two of the three oem gauges and a 2 1/16 clock into the oem pod. If the 2 1/16 clock wont fit Ill put a 45mm egt gauge in instead. Any suggestions would be welcome.
    Peter
    bambams247
    Where did you get the clock gauge, got a link? What does it look like. thanks!
    Jan 2002
    Colorado
    Peter,
    I have Autometer Phantom 2 1/16 gauges (6 of them). I have a boost, A/F (useless), and a clock in my oem pod. I used a blank piece of trim that the stereo places use and cut the holes. Not hard to do and looks pretty good.
    Good luck,
    Ronin
    "Having no way, is way.
    Having no limitation as your limitation."
    London, Ontario
    Bambam...clock gauge is available from Autometer and VDO
    Hey Ronin....I think the problem for me is that I have 2 oem gauges at 45mm and the clock I want is 52mm. I want the clock in the middle and I was looking for some kind of template for the faceplate to get me started. I am not very mechanically inclined and it would take me forever to do. Help Me!!!!! Please!!!
