amp question
Results 1 to 14 of 14
This is a discussion on amp question within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; in back of my fosgate amp it needs a "rem" wire to turn on, the guy that sold me the ...
    Registered User LUV2XL8's Avatar
    May 2003
    Wayne
    Question amp question
    in back of my fosgate amp it needs a "rem" wire to turn on, the guy that sold me the amp told me that that wire is on the RCA's cables wires (LEFT, RIGHT, and a small wire for "rem") ... now my question is where does that wire come from the HU:
    Fuse & Relay Box (ACC - Switched Power) (Yellow/Green wire)
    OR
    Main Fuse Box (BATTERY - Continuous Power) (Blue/Red wire)
    Registered User XtmX's Avatar
    Jun 2003
    Pittsburgh
    remote should be blue, usually labelled power antenna, and is switched 12v.
    Registered User randy98mtu's Avatar
    Apr 2003
    Whenever that wire is hot to the amp, the amp will turn on. So you want the switched power to it.
    '04 JBP Wagon 5MT
    bambams247
    The "rem" wire stands for "remote". It is a 12v source that allows it to turn on. Like a remote. When the remote wire gets power the amp will power on. You can run it from your head-unit using the blue remote wire, it should of came with your wiring kit. Or you can set it up for a toggle switch that runs 12v. The switch works great because if its a sub amp, you can turn on the subs with a flip of a switch. But if you do not want them banging you can turn them off. Good luck!
    bambams247
    Re: amp question
    OR
    Were you able to get that wired up correctly?
    Registered User 20wrx02's Avatar
    Oct 2002
    South East Mass
    remote rem
    if ur using ur stock radio connect it to the fuse box labeld radio... u can use that as a 12v switch...
    if u car using an aftermarket radio its the blue wire labled power anntenna... usually 4 or 6 ohms...
    May 2003
    Wayne
    im doing it tomorrow morning, hopefully it will say on the wire 12v. Its a stock HU, so if anyone has done this before i just need to know which color is the wire for remote (im going to use the yellow/green one first) ... If not then it will have to be trial and error ... thanks guys for your help
    Registered User Dream's Avatar
    May 2003
    MN, Twin Cities
    I think remote is the blue one...
    May 2003
    Wayne
    wait, ... blue/green or blue/purple ... oh man im gonna mess this up
    bambams247
    hey dream I love your icon!
    And amp guy, just sue a 12v power that turns on with the ignition, that way your amp will turn on everytime you turn on the car! you can do it that way!
    Apr 2003
    I tapped into the cig lighter. :shrug:
    '04 JBP Wagon 5MT
    Oct 2002
    South East Mass
    remote
    i use run a pre amp bazooka with the stock unit...
    just tap the REM with the radio fuse easy!!
    12v batt
    -12v ground
    REM radio fuse in fuse box
    trust me
    May 2003
    Wayne
    Cool
    I GOT IT WORKING IT WAS THE YELLOW/GREEN !!!! Thanks guys
    Mar 2003
    Hey Luvxl8 when you trun off your stock HU does your AMp turn off also ??
    I did a research about this and I believe Stock HU doens't have any trigger to turn off the amp You need to make your own swtich or put it with the inginiton In the fuse box....
