Amp 12V trigger
Results 1 to 7 of 7
This is a discussion on Amp 12V trigger within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Help - all you audio guru's. I am planning on using the OEM headunit with an aftermarket amp (plus replace ...
    Feb 2003
    Midwest
    Amp 12V trigger
    I am planning on using the OEM headunit with an aftermarket amp (plus replace door speakers and add sub).
    What can I use for a 12V trigger for my amp?
    Thanks!
    Registered User djrez4's Avatar
    Colorado
    I tapped the remote off of the clock power wire.
    Deliberating enclaves of like-minded people are often a breeding ground for extreme movements - Cass Sunstein
    Registered User randy98mtu's Avatar
    Apr 2003
    I tapped my radar and my amp off the cig lighter feed. You can do it by loosening the climate controls and just having someone lift them up so you can get to the wires.
    '04 JBP Wagon 5MT
    Feb 2003
    Midwest
    So any switched 12v will work?
    Apr 2003
    To turn it on, yes. But certainly run the power cable directly to the battery.
    '04 JBP Wagon 5MT
    Feb 2003
    Midwest
    Yes, I was just looking for info on the remote "on". (I have 4 ga. running to the battery and ground from 4x50 rms amp)
    Apr 2003
    Ok, good. It seems obvious enough, but you never can tell. I didn't want your next post to be "So I set my car on fire."
    '04 JBP Wagon 5MT
