Results 1 to 2 of 2
This is a discussion on Preventing Sub From Bouncing around... within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I am about to install a Single 10" sub in my car. It is small enough that the box looks ...
    Jan 2003
    I am about to install a Single 10" sub in my car. It is small enough that the box looks like it would be succeptable to bouncing around in the trunk. Anybody have any ideas on how to tie this thing down? I drive rather aggresively and I dont want this thing banging around in my trunk when I do some canyon carving.
    May 2003
    Wisconsin
    Your best bet would probably be to just mount it to the trunk bed with bolts. Fortunately the box in my car is really heavy so I just have it on foam pads and it doesn't slide. If you do bolt the enclosure, just get some brackets to screw onto the box, then drill and tap into the trunk bed and use bolts that fit. If you do bolt it down into the trunk, be careful when you are drilling not to hit the gas tank or fuel lines!
    - F r a n z
    Bucky with teh lime powah!
