Results 16 to 30 of 35
This is a discussion on Factory Turbo Gauge or Aftermarket within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; follow the above link to the installation instructions. It has excellent pictures of it installed. I'm sure the dealer can ...
    Registered User RogersWRX's Avatar
    Jan 2003
    Highlands Ranch, CO
    I'm sure the dealer can install this if you ask them. Some dealers won't touch aftermarket stuff and some will - it really depends. They won't warranty the part, but they will usually warranty their labor.
    Your warranty cannot be "voided" as a whole. They can only void the warranty on parts that you replace, or if they can prove that the parts that you replaced caused a problem with another part.
    i.e. if you put in a boost controller and blew up your turbo, they could void your warranty on a lot of stuff, but if you replace your muffler, there's not much else it can affect or that they could say.
    A mechanical boost guage is a passive device so can't really damage anything, but if it's not hooked up correctly, you could get a boost leak which they could charge you to diagnose and repair if your installation caused it.
    2002 White "STX" WRX Wagon
  2. #17
    Registered User Sick Boy's Avatar
    May 2003
    RogersWRX: Hey, I appeciated the help you gave me. One more question though. For '04, the WRX has a red needle now. I don't think Omori offers one with a red needle. Anyway, I opened up another post under "Cockpit and Cabin" looking for this. See: 2004 Turbo Gauge Swap
    2004 Sedan Stage IV (w/ .5L envy) >>> Stripped & Sold!
    2007 Wagon Stock >>> Soon to be traded in for an 08 STI
  3. #18
    Jan 2003
    Highlands Ranch, CO
    This guy has gauges for all the different years / colors now...
    http://www.j-spectuning.com/index.php?cPath=21_24
  4. #19
    May 2003
    Sweeeeeeeeeeeet. I looked there not too long ago and didn't see them. I guess I'm blind. Thanks again.
  5. #20
    Jan 2003
    Highlands Ranch, CO
    Actually, you're not blind. . . if you read the whole thread, you'll see he just got them in stock, and then just added them the thread after the fact!!
    Good luck!!
  6. #21
    Banned dark_rex's Avatar
    Aug 2001
    The Hub
    Quote Originally Posted by RogersWRX
    yup, you can use the existing power supply and vacuum hose from the factory gauge to install the Omori. Here a link to the installation instructions
    http://www.j-spectuning.com/45mm_column.pdf
    dead link.
    anyone have these instructions?
    dR
  7. #22
    Jan 2003
    Highlands Ranch, CO
    Here's the new link to the 'full' install:
    http://www.j-spectuning.com/installs/wrxmechboost.pdf
  8. #23
    Forgive my noob-ness,
    But, if I didn't get the factory gauge installed, will I have to run additional wires/hoses and/or get a different steering column cover before following the instructions you posted?
    Thanks for your help.
    -WOJ
  9. #24
    Jan 2003
    Highlands Ranch, CO
    Yes!
  10. #25
    aOh
    aOh is offline
    Registered User aOh's Avatar
    Jan 2005
    Virginia
    Jesus Roger your answering everyones problems.. so ill give you mine i want to put on my HKS exaust i ordered awhile ago but im afraid it will void the warranty. I saw that you said It will only affect the exaust part of my warranty. Is that true or did i just goof? Thanks a lot.
  11. #26
    Jan 2003
    Highlands Ranch, CO
    aOH, as far as a FULL turboback exhaust, that can get a little difficult as far as warranty, because since you're upping the power of the engine, some dealers will give you trouble if you roast your clutch or toast your engine etc... A lot of this depends on the dealer... If you're just doing a cat-back or axle-back, there's almost nothing to be worried about...
    I couldn't find an informative link on this forum, but here's a link to a good thread on another site, hopefully they'll let me post it here: http://forums.nasioc.com/forums/show...hreadid=111461
  12. #27
    aOh
    aOh is offline
    Jan 2005
    Virginia
    Great thank you so much for clarifing for me. I figured it wouldnt be to big of a deal but i was wonderin if there was any specific rules or guidlines. Thanks again Roger for your help.
  13. #28
    Roger, Thanks for answering my question, hmmm, I wonder if an aftermarket qauge will come with everything that I need. I guess I have some searching to do...
    Well, since Roger's in a question answering mood, I too was wondering about exhaust mods. I think I get the warranty stuff, but what about passing smog? Do you keep the old stuff around and put it back in before the check or do some of the aftermarket ones, (like aOh's HKS) that already pass?
    Thanks again,
    -WOJ
  14. #29
    Jan 2003
    Highlands Ranch, CO
    Okay... I think this thread has offically been Hijacked !!
    To answer your question... If you go turboback without any cats, you will have to replace the stock cat to pass emissions. Some states go with a visual inspection (California) under the car, and even if you have an aftermarket cat, you may want to install the factory back so that they don't give you a hard time.
    I would go with a down-pipe with a high-flow metallic substrate cat, so that you can pass emissions and still significantly reduce back-pressure...
    Helix makes a great one for $399 - I have it on my car... love it!
    http://www.gruppe-s.com/Subaru/subex/HelDPCat.htm
    or Cobb Tuning makes theirs - nice but $$$
    http://cobbtuning.com/wrx/power-i.html#s-downpipe $575
  15. #30
    Registered User FelixTheCat's Avatar
    Twin Cities, MN
    I just wanted to say thanks for posting the info on how to replace your factory gauge with one that is more readable (psi). I just aquired a 2005 WRX with the turbo guage. I would have never order the car with one, but it came with it so what the heck.
