'04 Gauge cluster
Results 1 to 15 of 21
This is a discussion on '04 Gauge cluster within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Does anyone know if you can swap out the '03 gauge cluster for the '04. It would be nice to ...
    Registered User Maxitt's Avatar
    Feb 2003
    CT
    Question '04 Gauge cluster
    Does anyone know if you can swap out the '03 gauge cluster for the '04. It would be nice to have the tach in the center, if it's possible where could we get it.
    Apr 2003
    CT
    Subaru would have it Had to say it, good luck with your search, the junk yards wont have any!
    '12 WRB Sedan
    Feb 2003
    CT
    Will it work though? Also, I've asked a parts guy @ colonial and he said they don't sell it, so my original question was meant to request a place online that I can purchase it.
    Registered User verbal's Avatar
    Oct 2002
    Whats the point? Swapping out the cluster will give you one big problem, the miles get reset to 0. Why does having it in the center instead of a few inches right make a difference?
    Apr 2003
    CT
    If you MUST have it... try http://www.subaruparts.com/
    '12 WRB Sedan
    Feb 2003
    CT
    The point is that I can't see it a few inches to the right. As far as the mileage, cant i just keep that part of the 03 cluster, pop it out or something.
    Registered User PlatinumWRX's Avatar
    Jul 2001
    PA
    Are you sure about that? I would think the mileage is embedded deep in some body control module somewhere. I had several displays in my oldsmobile and it always kept the correct mileage.
    -Jim
    Oct 2002
    -Jim
    I'm 90% sure. Back when nasioc was i-club, I used to lurk. Or maybe I saw the link in a thread here, can't remember.
    Somebody was having warranty issues because they swapped their cluster for the STi cluster. For one, the mileage is stored inside the cluster. So new cluster means mileage at 0 or whatever mileage is stored in the new cluster. PLUS the STi cluster is in kilometers. He had all kinds of service issues even though his mileage before the cluster swap was on record at the dealership. They gave him a real hard time. I'm not sure what the end result was.
    You said you can't see the tach, even though it's an inch to the right of the speedometer. But if you switched clusters, then you wouldn't be able to see the speedometer. I'm not sure about you, but seeing the speed I'm going is more important than seeing the RPMs I'm at. I've only been driving a stick since October '02, and I can get a pretty good idea of the RPMs by the sound of the car. Why not just get a shift light instead? I think it'll save you a lot of hassle.
    Don't get me wrong, if the mileage wasn't stored in the cluster, I'd get the '04 cluster in a second. I like the red needles much better than the yellow.
    Feb 2003
    CT
    I've talked to a dealer near me and he said that it can be done and the Gauge Cluster is around $100. He said the odometer can be set to the correct mileage by tuners outside of Subaru for around $60. So for around $160 it can be done, not too bad. I'll be doing it this summer and will post pic's soon after.
    Registered User Lightning's Avatar
    Apr 2003
    Delaware
    not to offend anyone here, but $100 for a gauge cluster (in my experience) is outrageously cheap. there's got to be more to it than this.
    s e t h
    "If you're going to live on the cutting edge, you'd better be prepared to bleed a little."
    Stink-Eye Mob #73, Hawkeye Alliance #667
    Registered User Hot_Dog's Avatar
    Jan 2003
    Albuquerque, NM
    I agree. I checked on a cluster for my 99 civic...it was $700 new. I found one at a junk yard for $50. But hey, if it really is $100 I'll be in line to get one!
    2003 WRB Sedan. Mods & Pics
    Quote Originally Posted by scooby-x
    OMG!!! Do you want me on my knees or bent over? I love you
    Feb 2003
    CT
    Hey there is a chance that the Gauge Cluster is more than $100 because the parts department guy only had a '02, '03 in his parts catalog,which he said was $100. That is why I said around $100, but he said '04 could not be that much more. There is no reason to debate the price here, I'm simply relaying what I was told and it seems to be a worth while mod if it is under $200. The guy at Subaru also gave me the name of a local tunning shop that will set the odometer to the correct mileage as well as install it if needed.
    Registered User Sunkist's Avatar
    Mar 2002
    Tucson, AZ
    If the WRX guage cluster is only that much then how about getting an STI guage cluster. I wonder how much a premium that will be??
    My woman hates the money pit
    2002 WRX Hybrid 2.5L 16G
    Oct 2002
    Why didn't you ask if you could put the '04 cluster in an '02/'03?
    If there is actually a place that will change the odometer, and the '04 cluster works in an '02, then I might actually consider this.
    A thought, so while your new cluster is at the place to change the odometer, you can't drive your car? I wonder how long it would take them to do it. If it would take them more than a day, that wouldn't be good.
    I really don't think it's worth the hassle of losing your warranty, if you still have a lot of warranty left. From what I hear, they aren't very good about keeping records. Or trusting their records.
    And why goto the STi cluster when the only differences between the '04 and STi is the STi logo? And maybe a shift light.
    Registered User KanosWRX's Avatar
    Dec 2001
    Northern VA
    The STI has an adjustable shift light Sugoi. Also it has and oil temp gauge I belive, but I assume you need some other things to get that to work as well.
    My Mods
    "The most important mod is the one behind the steering wheel" - Koyokid RIP
