custom door panels
Results 1 to 15 of 19
This is a discussion on custom door panels within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; heres my new front doors. it took forever, but i think they turned out pretty good. there was no room ...
    Registered User ervv173's Avatar
    May 2003
    FL
    custom door panels
    heres my new front doors. it took forever, but i think they turned out pretty good. there was no room back there for bigger magnets, so the doors had to come out some to hold the new speakers. - jl audio 6.5xr component set with the woofer below at an angle and the separate tweeter mounted where the stock one was.
    May 2003
    FL
    pic#2
    that last one had a wierd shadow on the edge of the pocket...heres another:
    Registered User Shard's Avatar
    Jan 2003
    Houston TX
    Damn, you did that yourself? Thats pretty clean. I'm impressed. Sound good?
    May 2003
    FL
    thanks. i had a lot of help doing them and most of the 5 weeks it took was trial and error plus hours of sanding. i learned a lot in the process though. for the rear i decided not to mess with the back doors, so i used a plasma cutter to make holes to mount 6.5" coaxials in the back dash. theyre mounted on mdf and everything is sound dampened. a jl 300/4 in the trunk powers everything. i think it sounds great, was well worth the work. the angle on the front speaks makes all the difference in the world.
    Registered User WRXin''s Avatar
    Jun 2002
    Houston, TX
    Looks good
    Shard -- if you ever need custom work done like this, get in touch with TeamShiftPoint. William can do some crazy custom work
    Fahd
    Floats like a butterfly and stings like when I pee!
    Jan 2003
    Houston TX
    Such as your antenna . Thanks fahd.
    Jun 2002
    Houston, TX
    Something like that
    Fahd
    Apr 2003
    CT
    Those look sick! Is that vinyl over them, or are they painted? Id it is vinyl, 2, or 3 way strechable? sweet!
    '12 WRB Sedan
    May 2003
    TUCSON, AZ, not east coast anymore :/
    nice work, you don't see to many new ideas these days. I stuck my 6" on the floor in some kicks, then 4" in the factory hole angled up, and then tweets up in teh plastic triangle pieces.
    (I just received my sound deadening to do my doors, but here is an old pic)
    And the tweets
    Sorry if I kind of hijacked your thread, didn't mean to.
    03 grocery get'n wagon
    Jun 2002
    Houston, TX
    And the tweets
    Very nice work
    Fahd
    Moderator MidKnight's Avatar
    Oct 2002
    Bergen, NJ
    Hey Ervv173, the speakers are attached directly to the door panel? How do you keep the panel from vibrating? Is it fiberglassed on the backside or at least dynamatted (or some equivalent)?
    '03 WRX
    '01 2.5RS
    MODS | PICS | Dyno
    "Stuff sold by the gram is always going to be more exciting than stuff sold by the pound." - Jeremy Clarkson
    May 2003
    FL
    heres the door 3/4 of the way dynamatted with the jl tweeter installed. the inside of the door is completely covered too. i used some stuff called Brown Bread, better than dynamat and half as expensive.
    Oct 2002
    Bergen, NJ
    I did my doors with brown bread too (and my trunk). The stuff is awesome... I definitely prefer it to brown bread...
    '03 WRX
    '01 2.5RS
    MODS | PICS | Dyno
    May 2003
    FL
    heres the backside. you can see the vinyl wrapped over the edges. the color isnt a perfect match but the texture is real close. the speaker itself is mounted into an mdf ring which is attached to the panel.
    May 2003
    FL
    eastcoastwrx: nice job man. im jealous...i wanted to do 3ways up front too. what did you do for the rears?
