good luck, i got the 04 and posted a thread all i get is people say why u waste ur money on that, blah blah blah, there were liek 13 replys not one answered my question,but if you figure it out let me know too, thanks
Originally Posted by DAVEJC
This is a discussion on 2003 pinout for A/F Gauge install??? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; 2003 WRX Sedan I've hooked up the A/F gauge, mounted it in the pod, routed the signal wire, and found ...
2003 WRX Sedan
I've hooked up the A/F gauge, mounted it in the pod, routed the signal wire, and found the ECU. All I need now is the right wire to splice at the ECU. I've searched and searched, but can only find the 2002 pinout. My 2003 ECU doesn't look the same. Does anyone know which wire I should use?
