Results 1 to 14 of 14
This is a discussion on Autometer Phantom Pyrometer vs. EGT Guage within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; When the Prodrive Performance Pack Stage 2 comes out, I plan on making my car a bit faster. Seeing as ...
    Registered User Bask Oner's Avatar
    Jun 2002
    Chicago, IL
    When the Prodrive Performance Pack Stage 2 comes out, I plan on making my car a bit faster. Seeing as how I don't have any guages yet, I should probably get some. I think that a good start would be a boost guage (Autometer Phantom 20 PSI) and EGT. Autometer's Phantom series includes a Pyrometer that comes with an 8' temperature probe, and measures from 0 to 1600 degrees. There is also an EGT guage, which costs significantly more, measures from 600 to 1600 degrees, and does not come with a probe. Would I be okay with the Pyrometer, and drilling the probe into one of the rear exhaust pipes?
    Links:
    $135 Pyrometer with Probe
    $220 EGT without Probe
    Matt
    WRX-less, now RSX-y!!!
    Jun 2002
    Chicago, IL
    Bump.
    Matt
    Registered User whap's Avatar
    May 2002
    North Canton, Ohio
    I am using the pyrometer one. Works nice.
    I stuck the probe in my downpipe, I think instructions say 4-6 inches down.
    02 WRB WRX
    --whole lotta mods
    Jun 2002
    Chicago, IL
    Got any pics of how the guages look installed? What are your other guages?
    Matt
    Feb 2002
    I think the probe needs to be like 6-8 inches from the cylinder to be accurate if you are going to use it for tuning.
    Moderator aussieinstlouis's Avatar
    Jun 2002
    S34 47.322 E138 29.131 (WGS84)
    I have the pyrometer one too. It is just fine, but it does need to be installed in the exhaust manifold - about 3 inches closer to the exhaust port than the stock front O2 sensor.
    The manifold is cast iron and can be drilled and tapped very simply.
    Jun 2002
    I'll post a pic tonight.
    Cheers,
    Andrew
    Registered User ripcuda's Avatar
    Feb 2003
    Colorado
    I have the Autometer Sport Comp Pyrometer and Boost gauge both mounted on the steering column. They match very well except the needle color (orange vs. yellow)...
    RR
    '04 SRT-4 E.blue
    ---past flyers---
    '03 WRX Silver
    '98 Maxima SE
    Jun 2002
    Chicago, IL
    Looks great! Thanks.
    Matt
    Jun 2002
    here's mine
    Jun 2002
    Chicago, IL
    That's exactly what I'm looking for; EGT via the pyrometer, A/F ratio, and boost. How does the A/F ratio guage work?
    Matt
    Jun 2002
    It works just fine. It is working off a narrow band O2 sensor so it is a 'health check' and not something you can tune by.
    Amarillo, TX
    Question
    Quote Originally Posted by ripcuda
    this is exactly what I am looking for. IS there a setup that matches the Factory Boost Guage? I want them both to look the same and I already have the Boost (came with the car). Now I need a similar setup for the other side of the column.
    Any help would be appreciated!!!!!
    Banned pputkowski's Avatar
    Nov 2004
    Middle GA
    I believe Omori or VDO guages would match the look of the stock boost guage...
