That shift light seems like it would be kind of useless, no? After all it comes on at 4k rpm.. you've got almost half of the usable rpm band left past that point!
This is a discussion on a cool shift light within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Look what I put in my buddies car this weekend http://www.ei0.com/upload/shiftlight.mpg if the link doesn't work for you, right click-save ...
if the link doesn't work for you, right click-save the target and play with media player
if someone would like to host this for me that would be great too.
2004 Black WRX Sedan
Mods = yes
i have a shift light it works good.
-Ben-
Spark it or Park it!
Right, but it probably comes on just before the redline, right? Not at 4k rpm I don't think...Originally posted by SpeedRacerWRX02
Mods = yes
i have the autometer with the pills.Originally posted by ryland
-Ben-
Ya, I've got no problem w/ that one![]()
Mods = yes
I had it set for 4000rpm's just for the video.
here are the specs, adjustable from 4000rpm to 10200rpm every 200rpm's, can be set to provide a flashing or steady light, choice of LED color. pricing- $55 to $60 shipped
I'm thinking of setting up a group buy for this, and I'm trying to get a feel for demand. So what do you guys think?
It could also be used as a cheap water/nitrous spray controller,
and I think it is cheaper than any other that I've seen.
thanks,
Brian
thanks,
Brian
Ohh, I gotcha, sorry if I came off as a little harsh beforeIt's a cool location, and looks like it'd be quite stealthy. I think that people will jump all over them w/ the different colored LED's. Maybe a progressive set of LEDs, that would start out green, then go to yellow, then red, as you neared redline? Kind of like this - T-Sport Shift Light.
Edited for typo's. Silly me.
Mods = yes
here are some pics of the install
http://www.shutterfly.com/view/pict...e21b374815ce44b
the password is - plastic
brief install description
Pretty easy install, it took me about 30 min. or so.
I couldn't stand that little bump on my instrument cluster, I figured it had to be good for something, and I wanted a shift light that wasn't very obvious. This provided both
1.dissassemble instrument cluster bezel
2.remove cluster, there is only three screws. and three molex connectors on the top edge.
3.unsnap clear plastic cover, then unsnap black surround.
4.the grey surround will now be loose, if you flip it over there is a swirl marked right where the bump from the front is
6.drill a 3/16 hole from the back, this depends on LED size
7.drill a hole on the bottom of the cluster for an exit for the LED wire
8.glue LED in place, and run wire behind dash
9.access the ECU find Tach wire and splice, run the wire to drivers underdash
10.wire the shift light box
11.set dip switches for activation point and LED style (flashing or steady) the picture of the dip switch's is hard to make out, but I assure you it is very simple
12.mount box with a few wire ties, easy to access with the fuse box cover removed.
I think I finally have a link that will work for everyone
http://216.169.147.239/egtech/shiftlight.mpg
Let me know how it goes
-Brian
Ok, Rub,
Im in, Get your arse on it!!..................![]()
Nice.
Shotgun
(wheres third?)
Group buy-group buy-group buy.
You're gonna have an angry mob on your hands if you don't set this up (leaves to light torch)![]()
I think i'd be in to.Originally posted by jedimaster
