did u look for writing on the wire? if no 1 knows then slide out the head unit and read the wires in the back.
This is a discussion on Quick wire color question within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Well i am planning on tackeling an amp install and i was hopeing i someone could give me the colors ...
Well i am planning on tackeling an amp install and i was hopeing i someone could give me the colors of the, right & left front speaker wire, and the color of the wire i tap in to for the remote wire which connects to my amp
thank you for the help
ben
-Ben-
Spark it or Park it!
Thanks for the help i didn't know they labeled the wires
i will have to look. Also if anyone can give detailed instructions on removing the head unit it would be apriciated. I have found a couple of threads but all im not sure where to go after the cup holder is removed.
thanks
ben
i believe there are a few screws that u can see after u take the cf or alum looking piece off.
-Ben-
there are six screws located behind the trim bezel....4 up high and easy to get at and the two down low and back farther...make sure to use a magnetized screwdriver so yo don't lose the screws!
totalled 1 wrx psm sedan
now onto '03 wrb wagon!!
Thanks for all the help. I finished the amp install in about 3 hours. It isn't nearly as difficult as i thought just time consumeing. The deck removal was just as easy as everyone made it seem. I did get some pictures during the install and hope to post some instructions for all who are interested later on
thanks for the help
ben
