apexi turbo timer need help
Results 1 to 2 of 2
This is a discussion on apexi turbo timer need help within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; i got everything hooked up except for the o2 censor wire on the ecu. does anyone have pics of this ...
    Mar 2003
    jersey shore
    i got everything hooked up except for the o2 censor wire on the ecu. does anyone have pics of this connect from their install or cal help me out i'd appreciate it
    Registered User aem421's Avatar
    Yeah I can help you out. I just installed mine on saturday. My f***ing digital camera broke or I would have taken pics. I was really pissed about that. Anyway, the ECU is under the passenger side floor. You have to remove the plastic door sill that holds the carpet down (clips...be very careful). After you remove the sill and pull back the carpet, there is a metal plate over the ECU. Remove it. If you are looking at the ECU where the wires are all coming out of, there are 5 clips. Remove the second one from the right. If you are still looking the wires coming out of the back, there are 3 rows of wires. You will want to splice into the one one the far right and the one two wires over to the left from the middle row of wires. One is for ground and the other is for the O2 sensor. You will have to peel back the black wrap that is around the wires to scotch lock the two wires together. After that, I used electrical tape to wrap around everything. Put everything back together and you are done. Mine works like a champ. Let me know if you have any questions. Hope this helps.
    '02 WRX/STi
