Can someone help me on instructions on installing boost and EGT gauge?
Results 1 to 12 of 12
This is a discussion on Can someone help me on instructions on installing boost and EGT gauge? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I have an carbon fiber 2 1/16 autometer gauges and planning to have them installed on the pillar. Can anyone ...
    Feb 2003
    I have an carbon fiber 2 1/16 autometer gauges and planning to have them installed on the pillar. Can anyone help me with pics and instructions? I'm a noob plz help
    Possibilities are ENDLESS...
    But, Currently,
    52mm Autometer boost + air/fuel ratio gauge on A-pillar
    TurboXS MBC @ 16psi
    Protorque Hi-stall torque converter
    Gruppe-S up-pipe
    Samco IC hoses
    Registered User Shard's Avatar
    Jan 2003
    Houston TX
    There are a lot of topics on this, i recently helped with a boost gauge question. And i know there are plenty of others, just search. (not intending to come off as a jerk good luck)
    MisterX's Avatar
    May 2002
    Prague, Czech Republic
    Boost gauge instructions can be found at Subaru Parts.com in the WRX section. Just find the boost gauge and the install instructions are included as a link.
    EGT gauge installation requires you to drill and tap the manifold to install the probe. In this regard you need to remove the manifold because if you drill and tap in on the car, metal shavings are going to run through your turbo. Tap the driver's side manifold and you won't disturb your uppipe. Don't install the probe in the uppipe.
    I assume you can tap power and find ground.
    Scoobymods.com may have covered both subjects as well. Good luck with your install.
    X
    Feb 2003
    THX FOR YOUR HELP
    But, Currently,
    TurboXS MBC @ 16psi
    Gruppe-S up-pipe
    Samco IC hoses
    Registered User Hot_Dog's Avatar
    Jan 2003
    Albuquerque, NM
    Here's where I installed my EGT sensor. I welded a bung onto the manifold.
    2003 WRB Sedan. Mods & Pics
    Quote Originally Posted by scooby-x
    OMG!!! Do you want me on my knees or bent over? I love you
    Feb 2003
    Originally posted by -=[JJFA]=-
    Yes, this subject sounds interesting, indeed.
    This is like the 3rd time I seen you put this in a thread.. you post wh0r3
    Registered User tuca33's Avatar
    Aug 2002
    Brazil
    Hey please,,i would love to see more pics as i am ready to install the EGT gauge but i am not sure where to install it properly.
    Help me out.
    Thanks
    Tuca
    2002 Black Wagon WRX
    315HP With the PM-ID
    MisterX's Avatar
    May 2002
    The gauge or the sender? The sender goes on the manifold on the Drivers side as clos to the exhaust port on the head as you can get.
    X
    Aug 2002
    Brazil
    But his picture is in the passenger side manifold.
    I was thinking of doing the pass side cause i will do the uppipe anyway.
    Hey,is it correct 4 inches away from the head?
    thanks
    tuca
    MisterX's Avatar
    May 2002
    The reason most people install on the driver's side is to avoid the uppipe. Insatall as close to the exhaust port as you can if you want good readings. If 4 " is the best you can do, OK.
    X
    Aug 2002
    Brazil
    When have to take the manifold to install the uppipe,,i will get the manifold and take it to a welder,,and weld the bung to it.
    The bung can stay 4inches away??thats what says in the EGT gauge manual.
    If i place it before the uppipe there will be no accurate readings?
    thanks
    tuca
    Jan 2003
    Albuquerque, NM
    I placed the bung about 4cm away from the exhaust port on the #3 cylinder (the front passenger cylinder). I put it on this side because I installed my uppipe at the same time. Also, I've heard that the #3 cylinder is the last in the fuel distribution series, so it is most likely to run lean.
    Tuca: I didn't take any pics of the manifold when it was out of the car (I wish I had). The hole points almost straight towards the front of the car. I drilled a 1 inch hole in the top heat sheld to allow the wires to come out.
