Results 1 to 7 of 7
This is a discussion on I've got a serious problem....need some help! within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Last week I installed an autometer boost gauge in my car. Everything's been working fine, but tonight none of my ...
    Jan 2003
    Simpsonville, SC
    Last week I installed an autometer boost gauge in my car. Everything's been working fine, but tonight none of my dash lights or radio, heating/ac lights would come on. When i turn the headlights on the clock and radio face don't dim either. What could the problem be? I tapped into a wire coming out of the cruise control button (it was purple if that helps anything). Blown fuse maybe? I checked all the connections and they're all still good (the ground is still fine, connection with the wire is fine too). Also, I didn't cut the wire I tapped at all, just stripped it and wrapped more wire around it. Anyway, any suggestions on what this could be? Thanks a lot.
    ~Adam
    Registered User Shard's Avatar
    Jan 2003
    Houston TX
    I'd definetly check the fuses man, main thing i can think of.
    Jan 2003
    Simpsonville, SC
    Yep, that's what it was. I guess i should've checked that before i posted. Sorry for the trouble. Do you think there could be a problem with the wiring location? I may need to try to tap another wire.
    Feb 2003
    How did you ground the autometer? If you actually hooked the ground up to the illumination wire within the car instead of a ground wire... as soon as you turned on your headlights the fuse would blow... This happend to me a few years back when i was installing a HU and figured the only wire left had to be ground... wrong
    Jan 2003
    Simpsonville, SC
    Nah, I just grounded it to a bolt going to the frame. It seemed like the easiest thing to do since i didn't connect it behind the stock head unit, but to the 12v wire running to the cruise control button.
    All seems to be ok though now (at least until another fuse blows.... )
    Registered User thechickencow's Avatar
    Mar 2002
    West Allis, WI
    Did the lights and stuff kick out while using the cruise control? I'm not sure I can picture exactly what your setup is, but where is the connection between your boost gauge and your dash lights. I'd trace from there if there is a connection for illumination that is tapped into there or something.
    tcc
    Jan 2003
    Simpsonville, SC
    Everything is fine now, it was just a fuse that blew because the 12v and ground wires touched right up next to the gauge.
