Autometer Boost Gauge Install Help - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
This is a discussion on Autometer Boost Gauge Install Help within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Mine usually idles at like ~17 vac. and max boost (w/ my cheap ass 3/16) is like 16 at WOT, ...
    Registered User Shard's Avatar
    Jan 2003
    Houston TX
    Mine usually idles at like ~17 vac. and max boost (w/ my cheap ass 3/16) is like 16 at WOT, when cruising i'm not at 0, i'm a little under.
    Registered User Blue2004WRX's Avatar
    Jul 2003
    Syracuse NY
    Shard, you tapped the vacuum hose that goes to the BOV for your boost gauge?
    --2004 WRB WRX--
    Still way too stock.
    Originally posted by MidnightFLAT4
    I like A/C for the sole reason that it makes the idle sound meaner.
    May 2003
    Palmdale, Ca.
    I did the same, thats how Subaru does it for the factory gauge.
  6. #19
    Jul 2003
    Syracuse NY
    Did you have to unmount the intercooler and move it back?? Doesn't look like I have much slack on that line, especially with my new BOV.
    --2004 WRB WRX--
  7. #20
    May 2003
    Palmdale, Ca.
    No, but, it was kind of a pain in the ass. Just got to pull on the hose fairly hard, and make sure you have some soapy water on the T fitting to slide it in easier. I also used a pair of needle nose pliers to help hold it in place.
  8. #21
    Jul 2003
    Syracuse NY
    Do you know what size the hose is?
    --2004 WRB WRX--
  9. #22
    May 2003
    Palmdale, Ca.
    The Blow off valve hose is 1/4, and autometer line is 1/8. I have a post about why the right size connectors are so hard to find, because it really is, for me at least.
  10. #23
    Registered User Weeeeeeeeeeeeee's Avatar
    May 2003
    Yorktown, NY
    Originally posted by aem421
    Try this...
    http://www.wrxtra.com/Documentation/doc-1003.pdf
    Let me know if that helps.
    seriously, where did you find an 87 gn?? those cars = sick
