swapping boost gauges
Results 1 to 7 of 7
This is a discussion on swapping boost gauges within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; i have the factory boost gauge, but i wanna swap it out for a PSI one. would it work just ...
    Registered User RexMobbin''s Avatar
    Nov 2002
    zipity here, zipity there, i'm zipity everywhere...
    i have the factory boost gauge, but i wanna swap it out for a PSI one. would it work just to leave all the wiring and hosing where it is, and just switch the gauge itself? and how do i remove the stock? is it bolted down or what? i don't mind the location, but i hate that MPa noncense. thanks
    Registered User Sputnik 5's Avatar
    May 2002
    SO CAL
    hey thats exactly what I want to do, come guys give us a hand
    Registered User is2scooby's Avatar
    Jun 2002
    Honolulu, HI
    I don't know what size the hose is to the stock boost gauge - but I think most other mechanical boost gauges could be made to work (possibly with an adapter to re-size the vacuum/boost source hose).
    Aloha, Richard...
    Retired Moderator
    TXS Stage 4 UTEC + TMIC + JoeP
    12.75 @ 105.67mph - 1.74 60'
    Registered User Shard's Avatar
    Jan 2003
    Houston TX
    Your most likely right, i don't see how they would use a hose so drastically different to not allow one to change, if worst comes to worst you could rig something up, like a hose to hose change. Very few gauges you can buy (that i know of) are as small as the factory gauge, you could use the wiring and the boost plumbing and just buy your own mount for it and be ok.
    Nov 2002
    i know this is a stupid question, but the stock gauge is a mechanical one, right? only reason i ask is cause i seen electronic ones that look the same as the mech ones. what is the difference anyway?
    Registered User Wrinkleboi's Avatar
    Jan 2002
    Langhorne, PA
    a mechanical boost gauge has the boost line running all the way up to the gauge, where an electronic boost gauge has the boost line running to a sending unit in the engine bay, and a wire running from the sending unit to the boost gauge.
    mechanical boost gauges have a hose coming off the back, where electronic gauges only have 2 wires (on mine at least).
    o-|-<) bryan
    -2003 Blue WRX, complete 2007 STi Engine/Drivetrain transplant - Pic 1 | Pic 2 | Pic 3 | Pic 4 (new!)
    -1994 Black Supra TT 6MT - Pic | Build/Restoration Thread: 67mm, Fuel, Painted Engine Bay, Fuse Box Relocation, Wire Tuck, etc.
    www.TriStateTuners.com
    Nov 2002
    ah, i see. thanks bryan
