Results 1 to 13 of 13
This is a discussion on Dash? Question within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Ok, underneath the steering wheel, to the left, that big plastic piece of the dash is loose, anyone have this ...
    Registered User Shard's Avatar
    Jan 2003
    Houston TX
    Dash? Question
    Ok, underneath the steering wheel, to the left, that big plastic piece of the dash is loose, anyone have this problem? where are the screws or whatever you use to tighten it? thanks. Also, how do you stop a clutch from squeaking?
    Aug 2002
    i think the plastic piece you are talking about is the plug to reset the ecu (don't mess with it)...dunno bout the clutch though
    Jan 2003
    Houston TX
    The plastic piece is a bad description on my part, it is the entire bottom of the dash panel, around the ecu plug matter of fact, the whole thing is just loose and it bugs me.
    Registered User Hot_Dog's Avatar
    Jan 2003
    Albuquerque, NM
    There's only 2 screws that hold in the plastic below the steering wheel:
    2003 WRB Sedan. Mods & Pics
    Quote Originally Posted by scooby-x
    OMG!!! Do you want me on my knees or bent over? I love you
    Registered User Judah's Avatar
    Mar 2002
    arvada, coloRADo
    I've broken two of the plastic screws and mine is extremely loose. I can't tell you how many times I have pulled that thing off.
    Registered User SubieGalRacing's Avatar
    WA
    screws you need are part number:
    045005163 - List price should be $1.90
    and.. if your clutch is "squeaking"
    do you mean just the pedal?
    or the clutch itself??
    Jamie
    Jan 2003
    Houston TX
    The pedal, excuse me.
    WA
    that could be just the spring being fussy...
    hit it with some WD40... see if that stops the squeak
    cheers
    Jamie
    Jan 2003
    Houston TX
    Tried good old WD before i even took it to the dealer. No luck there. Oh well.
    Jan 2003
    Houston TX
    I found out the dash prob, stupid car came without a pop it screw thing on the left side of the dash
    Registered User Prince Ali's Avatar
    May 2002
    Southern California
    Is the pedal squeaking or making a clicking noise? Mine would click very loudly when I pressed it all the way in. The problem was with the switch that is activated when you press the pedal all the way in. I took the swich off, carefully un-assembled it, put some grease on the internals (not the electrical contact points) and put it back on. The clicking is gone.
    Thanks,
    Ali
    Jan 2003
    Houston TX
    Nah, it's a squeak, and it's driving me nuts. The dealer won't/can't fix it, and i "lubed" it up and i got nothing. Dying for some help!
    Registered User pityr's Avatar
    Oct 2002
    Beaverton OR
    Its probably the bushing on the pedal. You can either replace it or get some silicone lube and put it on there. That worked on my MR2 when it started squeeking.
    No one will truely be free until nerd persecution ends.
