a pillar woes
Results 1 to 8 of 8
This is a discussion on a pillar woes within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I ordered a dual 60 mm pod from Lotek and I have been wrestling to fit in my 60mm greddy ...
    Dec 2002
    Dallas, Texas
    a pillar woes
    I ordered a dual 60 mm pod from Lotek and I have been wrestling to fit in my 60mm greddy gauges for an hour.
    Is the pod really supposed to fit in this tightly!? I even tried to open the holes a bit with some improvised hack saw action, but worked to no avail. Did anyone have this hard of a time fitting in their gauges into their pods like me?
    any tips or tricks?
    Registered User SubieGalRacing's Avatar
    WA
    maybe.. if they are not fitting at all...
    try dremeling out the diameter of the hole a bit?
    or... contact the place you bought them from and go over your issues with them?
    maybe they send you a 52mm pod instead??
    good luck to ya
    Jamie
    Registered User verbal's Avatar
    Oct 2002
    I've been wondering how 60mm gauges would look in the a pillar. I've seen 52mm but not 60mm. Post pics when you get the problems worked out. Good luck!
    Registered User NJwrbT-WRX's Avatar
    Apr 2002
    One Square Mile, NJ
    I think the Lotek pod has had a lot of fitment issues in the past, taht is why I decided to go with the slighly mroe expensive Autometer piece.
    -joe
    '02 WRB Sedan
    Removed silencer w/ Akimoto Velocity Stack, Blitz Dual TT, Autospeed Prototype Up-pipe w/ Flex-joint, Autospeed Crank Pulley, Autospeed OEM Dead Pedal, Samco IC Hoses, Axxis Pads, Goodridge Lines, Neo Synth Brake Fluid, Speedbleeders, Eibach Pro-Kit, Perrin Endlinks and Rear Sway, 17" Sub Zeros w/ 225/45 ES100s, Crucial Racing Thermostat and 1.4bar Radiator Cap, Autometer Sport-Comp Oil Pressure, EGT, and Voltmeter on the A-Pillar, STI Hoodscoop.
    Registered wrxinthehouse's Avatar
    Nov 2001
    awdpirates.net
    -joe
    Ditto
    Moderator Osiris's Avatar
    Jun 2002
    I used autometers gauge pod simply because lotek's pod had fitment issues. It will look nice if you get those gauges in.
    - Jason
    South East Region
    2002 Black and Bronze WRX
    "hihihi" - R.I.P. Jonathan Braxton Hawkins -
    Registered User JRod's Avatar
    Apr 2002
    Harrisonburg, VA
    my lotek 3 gauge A-pillar pod fit perfectly with autometer gauges.
    2002 WRX Sedan-Silver
    Turbo XS UTEC Stage IV (VF34)+TMIC, STI RA gears, Exedy clutch/flywheel
    Registered User blackshadow's Avatar
    Apr 2002
    Milan, Italy & Arnhem, Netherlands
    I don't know about the 60 mm. But i love my 52 mm dual pod from lotek. The gauge fit great and the quality was pretty good.
    autobahn storming scooby
