Results 1 to 15 of 15
This is a discussion on Passport 8500 Mounted within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; First I tapped into the power being put off by the 12v cig lighter, then ran the mute button right ...
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    First I tapped into the power being put off by the 12v cig lighter, then ran the mute button right under the dash at less than an arms reach while sitting
    I then ran the wiring back inside the dash over to the drivers side and strung it between the upper and lower dash panels. The flat wire fit fine, and there's a slit to run cables already there. The flat wiring slides right between the weather strip, but I pulled it out a bit so you can see it
    I then velcroed it so I can remove it when I go into areas where it's illegal. The detector is tilted upwards, so I used some plastic that I had and fashioned a small pillar to straighten it out.
    When I pull it off, the plug hides perfectly behind the glass of the windshield. When on, a cop cannot see it when approaching from the left rear or the right rear all the way up and into the windows.. Either side it's not possible to see. The view is blocked by the gauge shroud, and the a pillar. But if the cop approaches from the front it's blatantly obvious.
    Oct 2005
    Ocean Grove, NJ
    I did all that in one step
    Escort Solo S2 - done
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by Micah View Post
    Sweet! Tell me how well it works when the batteries are low, or you forget batteries
    Nov 2005
    Central Florida
    that looks good bro but it should be in the middle and also even... it kinda looks like its pointed down
    my boi has the solo he always has to buy bats for it
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Nov 2006
    Denver Metro Area
    It's just the pic... I leveled the bottom out and everything. Side to side it leans MINUTELY to the left... but otherwise it's straight.
    Nov 2005
    Central Florida
    o ok cool
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Oct 2005
    Ocean Grove, NJ
    3 sets of 15 minute rechargables with a mobile charger and home charger. Each set lasts me about 2-3 weeks.
    Nov 2005
    Central Florida
    what kinda bats ?
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Oct 2005
    Ocean Grove, NJ
    Quote Originally Posted by rr1911 View Post
    what kinda bats ?
    http://www.amazon.com/Rayovac-Minute.../dp/B0007TLJU4
    But there are many clones, Ratshack for one, and I have seen others. I have the Ratshack one, and a ton of rechargable batteries. They are effing great for remote controls. They are slightly lighter weight as well. Of course being rechargables they do hold a lesser charge, but the 15-minute charge time makes them great for general use. I've used them on plenty of digital devices as well, they work fine - just don't last quite as long as a set of alkalines.
    Nov 2005
    Central Florida
    cool man thanks for the info
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Oct 2005
    Ocean Grove, NJ
    http://www.nimhbattery.com/zts-mini-mbt-battery-tester.htm
    Here's another neat little toy.
    http://www.nimhbattery.com/zts-mini-...ery-tester.htm
    Nov 2005
    Central Florida
    ahhh thats cool... i didnt know they made something like that.... thanks again
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Registered User ntg06's Avatar
    Nov 2006
    MSG
    I want to get a radar dectector
    Registered User 96accord's Avatar
    Mar 2007
    Maryland
    Micah is a geek, but a geek that knows some cool products!!
    Oct 2005
    Ocean Grove, NJ
    Quote Originally Posted by 96accord View Post
    I'm a jack of all trades. Alot of random knowledge bolstered by an intense amount of websurfing and a reasonable amount of time spent reading.
    That should give you an idea of how much time I spend online. I'm not always logged in to youtube eihter, the youtube browsing I do on my phone (sprint mogul) doesn't count towards that number.
