ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
Go Back   ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums > Tech & Modifying & General Repairs > Interior Mods
Advertise On ClubWRX
Reply
LinkBack Thread Tools Rate Thread Display Modes
Old 07-07-2007, 11:16 AM   #1 (permalink)
How To Disable DRL's On 07 WRX
You would think it would be the same way as in the 06 being the same model and same headlights but i guess Subaru found out that everyone was installing HID's on their rides, so iguess they just wanted to make it a little more difficult to deactivate the DRL's. If you know what your doing it actually is real easy.
1. Remove glove department it has about 6-8 screws
2. You will see 2 big connection adapters a Black/Blue (black one is what youll be working on)
3. Disconnect the BLACK adapter youll see 5 wires but the only one you need to worry about is the CENTER one it is YELLOW with a RED line. Now theres 2 YELLOW with RED line wires but again just the middke one needs to be disconnected
4. You can do it the fast way and just cut that wire (middle one) and thats it your done,but if you ever want to reactivate your DRL's youll have some problems. So it takes a little longer and a bit frustrating to unplug the wire but trust me its the best way.
5. Once its disconnected then just put everything back in place and your done my friends!!!!!!
aNTEK is offline   Reply With Quote
Old 07-07-2007, 12:38 PM   #2 (permalink)
Slider's Avatar
How did you just disconnect that single wire?
__________________
Semper Fi
The Hawk-Eye Alliance #62
Military Militia #11
2007 WRX TR, WR Blue: Stg 2
Slider is offline   Reply With Quote
Old 07-08-2007, 11:19 AM   #3 (permalink)
DRL"S on 07 WRX
Its more like pulling out the wire SORRY!! you'll need some thin pliers. you have to take out the white adapter inside the black connector. it has little clips on the side that come out evenly. once its out just push the wire through and it will come right out!
Old 07-08-2007, 03:42 PM   #4 (permalink)
Here is how I did it on My 07 WRX
WhiTe_07_WRx is offline   Reply With Quote
Old 07-11-2007, 10:31 AM   #5 (permalink)
Thats one way to do it but when you take it in for service they can see that easily and they might tell you something. but hey if it works easier then go for it!
Old 07-11-2007, 02:12 PM   #6 (permalink)
only takes two seconds to plug back in also! hehe
Old 07-11-2007, 06:59 PM   #7 (permalink)
yeah thats true hey whatever works better! i just remember reading post about the 06 wrx doing this but the DRL's would still turn on!
Old 08-10-2007, 08:22 AM   #8 (permalink)
awdwill's Avatar
Send a message via Yahoo to awdwill
disable DRL'S on 2007 STI
Will this also work on the 2007 STI. I hate the DRL'S.
awdwill is offline   Reply With Quote
Old 08-17-2007, 04:04 PM   #9 (permalink)
gjohns7's Avatar
hey white_07_wrx thanks for the pics, worked no problem on my 07 wrx.
gjohns7 is offline   Reply With Quote
Old 08-18-2007, 06:44 AM   #10 (permalink)
Red face
Still thinking 2 do it 2day or Dnt....huh
__________________
____________________________________________
07 WRB
Intrax LWRNSprings, Greddy FrntSB, SPT Intake, Invidia(catless) 3" Dpipe, Skunk2 CB 3", STI Tmic, AutoMeter Gauges, 8K McCuluch HiD Kit
Subie - is the style of Life
Stero1D is offline   Reply With Quote
Old 08-29-2007, 08:01 PM   #11 (permalink)
zsimpreza's Avatar
Is this the same on the base 2.5i?
zsimpreza is offline   Reply With Quote
Old 03-27-2008, 09:56 PM   #12 (permalink)
hi there buddy can you send me the pictures of how to disable the drls for my wrx 07 please send it to my email
reinhardq-hotmail
thanks
reinhard79 is offline   Reply With Quote
Old 04-04-2008, 11:23 AM   #13 (permalink)
Quote:
I have an 07 base 2.5i and I just cut the MIDDLE yellow wire with the red stripe, taped it off and no more DRL. All other lights work fine. If I ever need it hooked back up ill just solder the two wires back together again. Its the black relay behind the glove box. If your just going to cut it you dont even have to take the glove box off just look under. Takes 2 seconds.
mustang492 is offline   Reply With Quote
Old 06-05-2009, 12:19 AM   #14 (permalink)
ive got good idea from this post.. I learned how to disable DRL's On 07 WRX,,and maybe I can apply it to my bmw e39..
kurtdaniel is offline   Reply With Quote
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Let's play a game kingb333 Mountain States 43 05-22-2008 09:21 AM
JDM Subaru WRX STi Adampops STi Technical Forum 33 09-07-2007 01:41 AM
Kartboy-Carbotech-Progress-Noltec-Perrin-Eibach-KYB-STi-Speed Bleeder-Goodridge&More! OakosAutomotive Vendor's Forum 5 07-12-2007 10:35 AM
'07 WRX TR or '07 WRX? Audio advice needed Spudlite New Member Hangout 2 03-18-2007 04:15 PM
Advertise On ClubWRX -->
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.1.0
Copyright 2001-2008 ClubWRX.net
Inactive Reminders By Icora Web Design
