SBC-ID...where to mount it?
Page 1 of 3 123 LastLast
Results 1 to 15 of 31
This is a discussion on SBC-ID...where to mount it? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I just got a used SBC-ID v1 (which I'm VERY excited about btw) and I'm trying to find a good ...
    Moderating YOU
    before you had your Subaru!
    Verdugo's Avatar
    Jan 2002
    Sea-Town, WA
    I just got a used SBC-ID v1 (which I'm VERY excited about btw) and I'm trying to find a good location for it. I've got my Blitz turbo timer next to my cupholder, so I'd rather not take that off. I was thinking on top of my steering column would work great, but what would I use to mount it there?
    Any other suggestions would be most welcome
    Armin - ClubWRX Admin/Moderator since 2002
    Vice President and Editorial Manager, NWMotiv.com
    Photography Portfolios: ArminAusejo.com | ArminWeddings.com
    President, Project One Car Club
    02 WRX "EVA-00" | 15 Audi S3 "Ella" | 2010 A4 (traded in) | 02 M3 "M-Thrizzle" (traded in) | 08 STI "Blaze" (sold)
    djrez4 is a genius | ScoobyDMC #010
    Registered User Vostok 7's Avatar
    Dec 2002
    Limehatless Avatar - I'm a trend scoffer.
    That's the dual solenoid one right?
    Lemme know how the install goes, I might get one of these someday.
    Vostok 7
    BUGEYE 4 LYFE! Or uh maybe not
    RIP Team Intrinsic Viva la Project 1! http://www.prjct1.com/
    2003 Subaru Impreza WRX Sedan 4EAT Aspen White "Akane"
    Mod List, Picts
    2004 Subaru Impreza WRX STi Sedan Aspen White "Akane II"
    Moderator aussieinstlouis's Avatar
    Jun 2002
    S34 47.322 E138 29.131 (WGS84)
    How about this?????
    Moderating YOU
    Verdugo's Avatar
    Jan 2002
    Sea-Town, WA
    That works, Aussie...double-sided tape? Velcro?
    Oh yeah Vostok, I'm probably gonna install it with the help of Ivan at the Installfest...I'll let you know how it goes
    Registered User snailwrx's Avatar
    Nov 2002
    hickory, nc
    tuca33 had a pretty good install if i remember correctly.
    autobots transform
    Moderating YOU
    Verdugo's Avatar
    Jan 2002
    Sea-Town, WA
    Yeah I saw Tuca's, but I don't have a PowerMeter-ID and I've still got the stock stereo, so no spare DIN for me
    Moderator schischwein's Avatar
    Jul 2001
    I would say fashion some sort of mount in the dash cup holder...ie the SBC ID falls and hangs when you pull the cup holder out or pops up from it. It would be hidden neatly when you don't need it glaring in your face.
    Moderating YOU
    Verdugo's Avatar
    Jan 2002
    Sea-Town, WA
    Indeed, but I'd like to use it as my primary boost gauge now, since it'll read in PSI No more BAR => PSI conversions in my head anymore! hehe
    I read on NASIOC that Blitz has some special mounting hardware that's specific for the SBC-ID and PowerMeter-ID, which lets you swivel it on a ball-type device...I'm going to have to look into that.
    Jan 2003
    Long Island, NY
    If you find this out, let me know. I have both a SBC and power meter and don't know where to put them. I am out of room in my car. So far I have Defi gauge pod in place of the clock, EDFC in place of the ashtray. i am looking for a spot for AFc and two Blitz things. Any suggestions would be great.
    Thanks
    Drew
    SQC #049
    Registered User QuickSilver's Avatar
    Bay Area, CA
    The best that I've seen is on the center flip-down sun visor. Can't find the thread that shows pics, but I'm sure people remember it.
    '02 Plat. Wagon, Manual
    Jun 2002
    I made a small elbow bracket from strip aluminium (3/4 inch wide) that I screwed to the inside curve of the gauge shroud. The SBC-iD is double sided taped to the bracket. You will notice that any pushing on the jog dial is transferred to the gauge shroud.
    It was very very easy and the only tools needed were a $5 hacksaw to cut the strip (I had to buy 3 feet of the stuff!). The bending was done over the edge of a table. And a drill to drill the holes in the bracket and the shroud.
    The shroud is the piece that you can take out very easily - it is not part of the gauge cluster. The whole thing only took me about 30 minutes to fabricate and fit! The cable routing is very easy also - it just fits between the dash and the kickpanel that drops away.
    I like it because I look down and I have rpm and boost in the same spot. Plus - it is unique....that is, unless you do it also... ........just joking - if you like it - go for it!!!
    I liked the LOOK of the sunvisor install - but it is WAY out of your field of view and a long way from your tacho. My radar detector resides above the mirror now and the gate opener for my apartment is also clipped to that flap!
    I will take some pics of the bracket for you this afternoon
    Cheers,
    Andrew
    Moderating YOU
    Verdugo's Avatar
    Jan 2002
    Sea-Town, WA
    Sweet, thanks Andrew...I'll definitely consider it
    Registered User djrez4's Avatar
    Colorado
    All that work and your SBC-iD can't communicate with your Powermeter! Aussie....dude....buddy....come on now
    BTW, My control unit just sits in the coin tray in front of the shifter. I haven't found a place to mount it yet.
    Deliberating enclaves of like-minded people are often a breeding ground for extreme movements - Cass Sunstein
    Jun 2002
    Very true - but I never use the functionality. I had rigged an extension to the bracket so that they could be side by side, but I never wanted to show the powermeter info on the SBC so I went for what I though was a more elegant solution.
    Honestly - I got swept up in the 'bling' factor of the Power Meter when I bought it. It is a toy, not a serious instrument. It looks cool and the guys at the car wash who do the dry and interior clean always comment etc etc They both say "Blitz in a little animation when you turn the car on - blal blah.
    I would recommend to anyone else to save their money and get a G-Tech for when they want that info. IMHO the Gtech would be more accurate anyhow.
    Cheers,
    Andrew
    Oct 2002
    hmphh~ what about apex product?? the boost controller, and rev/speed meter? Where do you mount them??
