Results 1 to 15 of 15
This is a discussion on sti cluster in 02wrx within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; i've done a little reading and found a few posts, but nothing with real good info background. does the 04 ...
    Registered User ezzzey's Avatar
    Apr 2006
    does the 04 or 05 sti cluster fit into 02wrx's, or does it need heavy mod?
    and can anyone confirm that the 02-03 wrx sti cluster NEEDLE lights up RED but the numbers light up GREEN? (lame)
    any help would be appreciated, thanks.
    Registered User RossLH's Avatar
    Apr 2007
    Ellicott City, MD/Flint, MI/New Bern, NC
    Quote Originally Posted by ezzzey View Post
    The answer to that one is pretty simple. There is no bugeye STi.
    Bugeye Mafia #130
    '03 SRP WRX sedan. Engine mods - SPT intake, Perrin sport tone catback, stage 1 tune. Suspension mods - lots, excluding only the springs, struts, and tophats. Plans - dont screw this one up.
    Registered User jaqattack02's Avatar
    Sep 2005
    Richmond, Va
    Quote Originally Posted by RossLH View Post
    Correction, there is no USDM bugeye STi. There most certainly was a bugeye STi overseas.
    And from what I can see in this image, it looks like a yellow needle, and more than likely green numbers, but they aren't lit up so you can't tell.
    Pictures from http://www.supercarsite.net/subaru/impreza-wrx-sti/2002
    Blobeye Syndicate #035
    Cobb Stage 2
    Aug 2002
    Virginia Beach, VA
    STi cluster is essentially identical to a WRX as far as color scheme goes for the 02/03 models. The difference is the shift light, STi logo, and different rev limit.
    The 04/05 cluster from a US STi does fit in and can work just as a plug and play, but I believe that the DCCD light stays in a weird mode and that one or more functions may not work as they should....there is something easy you can do to fix it, I just can't remember what...maybe try Nasioc?
    Toboggan T0rque's Avatar
    Dec 2004
    Your Mommas
    That pic shows the difference to me of the tach being better because it is heads up (center of cluster) and the speedo being to the right.
    Lead Wrench @ WTF Tuning, LLC
    Registered User SonicYellowWRX's Avatar
    Aug 2002
    Quote Originally Posted by LPPTundWRX View Post
    well, i thought that was the main reason to buy it, but that shift light beeper does wonders... and i never have to look at the tach. (its been a while since i drove an STI, but i don't recall it being as audible as mine)
    bugeye STi ones are all plug and play, except you wont have the temperature reading unless you hook that up somehow. (i dunno how, dont care)
    04+ I thought you had to modify it somehow... and you'd lose some of the functions. I dunno, I just stopped reading when I heard it wasn't plug and play... found one that was instead.
    Apr 2007
    Quote Originally Posted by jaqattack02 View Post
    Indeed, I was just speaking of USDM. You are correct.
    Bugeye Mafia #130
    Sep 2005
    Richmond, Va
    Quote Originally Posted by SonicYellowWRX View Post
    What did you do about the speedo being in KM/H instead of MPH?
    Cobb Stage 2
    Aug 2002
    KPH----MPH
    30-------19
    50-------31
    60-------37
    80-------50
    100-----62
    120-----75
    Sep 2005
    Richmond, Va
    KPH----MPH
    30-------19
    50-------31
    60-------37
    80-------50
    100-----62
    120-----75
    Nice! Isn't it possible though, to get the gauge face that has MPH on it and just stick it in there? Going between the 2 doesn't change the needle any, does it? It points to the same place whether it's 80kph or 50 mph, the difference is just the number behind it.
    Cobb Stage 2
    Aug 2002
    umm i dunno... i guess it should point in the same spot. i suppose you could pull apart the assembly and put your stock MPH gauge there or even get some nice APC ones to put in there.
    Registered User xMDxWRX's Avatar
    Jan 2006
    Towson MD
    KPH----MPH
    30-------19
    50-------31
    60-------37
    80-------50
    100-----62
    120-----75
    wow that would be fun to always be thinking about
    2004 VW GLI "Back In Boost "
    Quote Originally Posted by KanoWRX View Post
    well...IMO, or IMI (In My Imagination) WRX's/STi's are still better that Evo's...hands down...despise the facts.........
    Aug 2002
    well i did some searching and i found a nice plug and play converter to show kph as mph for those of you who care... http://www.iaperformance.com/product...oducts_id=2241
    Jan 2006
    Towson MD
    alot better
    Sep 2005
    Richmond, Va
    What does that do? Make your kph speedo show mph instead?
    Cobb Stage 2
