Results 1 to 8 of 8
This is a discussion on Stock Boost Gauge within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; The stock boost gauge from subaru came with my 07 wrx...its kinda confusing on how to read it...anyone know what ...
    Registered User PLSubaru98's Avatar
    May 2007
    Edison, NJ
    Stock Boost Gauge
    The stock boost gauge from subaru came with my 07 wrx...its kinda confusing on how to read it...anyone know what its measurement is....is it in bar???? Thanks.
    Moderator
    Jul 2003
    Maryland
    It's not in PSI.
    Quote Originally Posted by PLSubaru98 View Post
    Doesn't it say on the face what the units are? The Pa is an SI unit (1 newton per square meter) but bar is not, so using hPa brings the numerical value to the equivalent of mbar. This means you're reading mbar when you're reading hPa.
    You can convert either to PSI but I don't and I won't bore you with it.
    Registered User project_skyline's Avatar
    Mar 2006
    Silt, Colorado
    Its in some stupid unit measurement which is why i tell everyone not to get it.
    Moderator
    Jul 2003
    Maryland
    Quote Originally Posted by project_skyline View Post
    Rather then just learning what the conversion is.
    Its in some stupid unit measurement...
    The Pa is an SI unit. By definition, it's a standard unit.
    Registered User lordcon's Avatar
    Sep 2005
    Abingdon MD
    to the OP:
    The pressure unit that the stock boost gauge is in is mega pascals. (MPa)
    .1 MPa= 14.5 Psi
    You're welcome, the end.
    Administrator TheJ's Avatar
    Dirty South
    Smile
    Quote Originally Posted by TheJ View Post
    Welcome to the Club!
    The stock boost gauges, on both of my WRX & STi, measures in MPa. "MPa" is Megapascals (The pascal unit is named after Blaise Pascal, the eminent French mathematician, physicist, and philosopher noted for his experiments with a barometer. The name pascal was adopted for the SI unit newton per square metre by the 14th CGPM in 1971.)
    The conversion of Mpa into psi is basically: .10 MPa = 14.5 psi (Actually it's more like 14.503770000000001 psi, but 14.5 is close enough.). Or you could always just go to one of the many conversion calculators on the web like this one.
    +1
    -The J
    New Members, CLICK & BOOKMARK these links:
