Retained Accessory Power for windows
Results 1 to 6 of 6
This is a discussion on Retained Accessory Power for windows within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I kinda want my windows to work after I shut the key off, but only till I open the driver's ...
    Registered User 68sprintb's Avatar
    Dec 2005
    San Jose, CA
    I kinda want my windows to work after I shut the key off, but only till I open the driver's door, so I looked around and made this:
    it's just a relay wired to hold power until the ground through the driver's door is opened. power for the relay comes from the same ignition switch fuse until the key is off, then it gets pulled from the fuse that holds the circuit breaker and main power to all windows. the relay pulls about half an amp so that's no big deal, the windows still get power through the same fuse, and the 1 amp diode is there to keep power from flowing back into the accessory circuit after the key is off. I'm just wondering what you guys think...
    Blobeye Syndicate #75
    2005 OBP WRX Sport Wagon
    Stewart Warner Boost & Oil temp gauges / OEM 20 mm rear bar
    Cobb stg 2 / STi uppipe / Crucial Racing downpipe
    Stromung 2.5" catless centerpipe / ScoobySport New Age centre pipe & backbox
    Registered User tayhadar1's Avatar
    Apr 2006
    Spokane, WA
    That's a pretty good idea, and that would be nice to have
    2004 WRX Sti Cobb Stage 2
    GO COUGS!!!
    Registered User Lithoss's Avatar
    Nov 2006
    Wichita, KS
    Interesting. Are you an EE or electrician?
    Do you have a stock wiring diagram for the window circuit? Or, maybe just show on the drawing which wires/components you are adding? I can figure most of it out, but non-EE's (etc) might have trouble.
    Just checking your drawing, are the window motors controlled directly by the switches? Or do the switches operate relays for the motors? What else grounds back to 1B30?
    Looks good.
    Dec 2005
    San Jose, CA
    Quote Originally Posted by Lithoss View Post
    EE i guess, though not officially so as I'm still in schooling...
    most of that is the stock wiring diagram, the only parts I've added are the relay and associated wires. i'll add on labels for ease
    the window motors are controlled directly by the switches, that's the part I left off cuz I didn't want to mess with that & I'm only changing how the switches get power. the actual function for each window stays the same. that connector goes only to the master window switch on the driver's side, left off cuz I don't wanna mess with that.
    Looks good.
    thanks
    Nov 2006
    Wichita, KS
    Quote Originally Posted by 68sprintb View Post
    thanks
    Okay, yeah just figuring it out to double check for you. You added the 87A relay, correct? Because the only 'relay' shown on the drawing is the power window relay, which looks like its stock.
    I'm an EE @ Cessna aircraft
    Dec 2005
    San Jose, CA
    a double check was exactly what i was lookin for i updated the pic to include more info to the added circuits... the second relay is just a standard bosch relay, i may use something smaller since i don't need the bosch's 30 amp capacity.
