Page 1 of 5 12345 LastLast
Results 1 to 15 of 61
This is a discussion on Oil pressure sender installation within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Someone told me that installing the sender was as easy as locating the vehicles oil pressure switch. the thing that ...
    Registered User Buzz's Avatar
    Feb 2007
    rochester
    Someone told me that installing the sender was as easy as locating the vehicles oil pressure switch. the thing that tells the car to trip a cel when the oils low. does any one know where it is. i have an 06 tr
    Registered User 68sprintb's Avatar
    Dec 2005
    Cupertino, CA
    on MY05 WRX it's in the block kinda behind the alternator. it just has one wire going to it.
    Blobeye Syndicate #75
    2005 OBP WRX Sport Wagon
    Stewart Warner Boost & Oil temp gauges / OEM 20 mm rear bar
    Cobb stg 2 / STi uppipe / Crucial Racing downpipe
    Stromung 2.5" catless centerpipe / Scooby Sport New Age centre pipe & backbox
    Registered User Lithoss's Avatar
    Nov 2006
    Wichita, KS
    I just did mine yesterday and its a little harder than just finding the stock dummy guage one. I have a '06 TR as well.
    These should help:
    http://www.scoobymods.com/forums/showthread.php?t=612
    Oil Pressure Sender Install - Advice
    Feb 2007
    rochester
    i saw the one behind the alternator. i cant access the pics pecause im not a member of scoby mods. ill get my membership soon. the other guy said it needs to be romote mounted. that may be true but it does look like it will fit behind the alternator. (if thats the factory one). if i remove the factory one and install the auto meter sender. im thinking ill get a CEL cause there is no place to attach the wire the goes to the factory sender.
    thanx for the help guys if anyone else knows any thing don't be shy
    Dec 2005
    Cupertino, CA
    the PCM doesn't care about that wire, it's only for the gauge cluster so if you as long as you cover it (so it can't ground anywhere) it just means you're oil pressure light will never get lit again. it may be better in the long run to keep the factory oil pressure sender and use the drilled hole on top of the block, it's easy enough to get to and you don't have to modify the stock system (which is one of my goals whenever i change anything).
    Feb 2007
    rochester
    thats probly what ill do. there is a replacment plug for that hole on top with a 1/8th adapter hole from subaru. thing it auto meter elec sender wont screw in to it so im going to see if i can get it tapped. maby its in metric
    Registered User mykedude's Avatar
    Mar 2004
    Queens NY
    Quote Originally Posted by Buzz View Post
    The Subaru plug is a metric thread 1/8 PT. If you use a Defi gauge, Apexi or Greddy you will be fine with that.
    If you use an Autometer type of sender, it is easier to get this kit from WRXtra:
    http://www.wrxtra.com/catalog/produc...products_id=34
    ~myke
    ::2004 JBP WRX::
    May 2005
    Phillytown, PA
    Quote Originally Posted by mykedude View Post
    Just to clarify it is a 1/8 BSPT. Neat product.
    Oct 2005
    long island
    I just received the plug from subaru to thread into the top of the block. It fits 1/8 BSPT, the only problem is that it didn't come with a sealing washer. I am going to the local auto store to see if I can fine a copper washer to fit.
    06-wrx: stage 2 and loving every minute of it!
    Dec 2005
    Cupertino, CA
    they're also available from the dealership since it's the same size as the oil pan crush washer
    Nov 2006
    Wichita, KS
    Quote Originally Posted by 06-wrx View Post
    mine didnt have a washer either. but there wasn't one on the stock galley plug either so i just put the adaptor in without it. its been in there for a week or so, i had a leak at the connection where i remote mounted the tubing to the sender that i fixed, but no leaks at the galley plug. but then again i used a good ring of threadlocker on there too.
    so i dunno, unless someone else here says that its essential, i'd say you can install it wihtout it.
    Oct 2005
    long island
    I checked the oil pan crush washer on the adapter plug and it seems a bit too big. Maybe I will try and find a washer to fit the plug as best as possible and use a small amount of teflon tape on the threads.
    Quote Originally Posted by 68sprintb View Post
    May 2005
    Phillytown, PA
    Don't use teflon tape on the treads. Most likely your oil pressure sender will ground itself on the motor. The teflon tape will act as an insulator and you will get false readings from the sender due to it having a faulty ground.
    Oct 2005
    long island
    Quote Originally Posted by wrx wagone View Post
    WOW I guess I had a brain fart for a moment there. Thanks
    Oct 2005
    long island
    My Defi's were delivered today and the instructions show the use of teflon tape for the sender. What do you guys use on the threads to prevent leaks? I understand it is a pipe thread, but I would figure there has to be something that could help seal better and be conductive at the same time. Any thoughts??
