boost at idle
Results 1 to 4 of 4
This is a discussion on boost at idle within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; hi all, first off I searched There was a mixed bag of answers. Im probally overreacting, but I just installed ...
    Registered User kawshon's Avatar
    Jun 2002
    hawaii
    boost at idle
    There was a mixed bag of answers. Im probally overreacting, but I just installed my new Apexi boost gauge in KPA's. I had an autometer 52mm, in psi, which worked great, it was just damn hard to see.
    Anyhow, at idle im getting -.4
    Some of you said normal, but most said -.5 to -.6
    Is there something wrong with my setup? Nothing seemed to be out of the ordinary. Lines not kinked, no noticable leaks...
    Did a 3rd gear pull to 5k boost was a lil past 1.1, im not stock btw
    I should have double checked the boost with my old gauge first, but when UPS comes out of the blue, all hell breaks loose
    talked to is2scooby earlier, he said it was normal and if he could he would have, he-b!tch man slapped me over the phone for being so paranoid.
    Anyhow, sorry for rambling, TIA
    Wes
    Registered User is2scooby's Avatar
    Jun 2002
    Honolulu, HI
    Aloha, Richard...
    Retired Moderator
    TXS Stage 4 UTEC + TMIC + JoeP
    12.75 @ 105.67mph - 1.74 60'
    Registered User QuickSilver's Avatar
    Bay Area, CA
    According to my autometer boost gauge, the vacuum pull varies. When I start the car in the morning, i get about 20 mm of Hg (i think it's in mm), turn on hte lights: a little less, when i'm cruising on the freeway off boost, it drops to like 22 mm Hg. When the weather was warmer, I don't remember it dropping so far.
    Basically, I know that it'll vary according to conditions so I won't sweat it if it's not the same. Also, there's got to be some variances between different gauges of the same make, between diff. makes, etc..
    So you better duck...the back of the hand is coming your way! Stop being paranoid.
    '02 Plat. Wagon, Manual
    Registered User JimDab's Avatar
    Anaheim, CA
    i was getting -.430 on the AVCR
    after uppipe and downpipe im now getting around -.550ish
    im sure whatever it is is normal, just depends on breathing mods probably
    i never even thought much of it even when it changed
    2003 WRBlue Pearl Subaru Impreza WRX Sedan
    For Go: APEX'i AVC-R, Godspeed Uppipe, Samco IC Hoses
    For Show: JUN Eyelids, Clear Side-Markers, Momo RaceAir Shift Knob
    For Handling: Eibach Pro-Kit Springs, Cusco Rear Sway Bar
