Results 1 to 2 of 2
This is a discussion on Sound Dampening within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I want to see if I can quiet down the interior of my WRX wagon a bit. I was thinking ...
    Mar 2007
    Sound Dampening
    I want to see if I can quiet down the interior of my WRX wagon a bit. I was thinking of putting sound dampening in the doors...
    Is there anywhere else I should put it?
    What kind should I use?
    Franklin, WV
    http://forums.nasioc.com/forums/showthread.php?t=375468
    http://forums.nasioc.com/forums/showthread.php?t=864404
    Doing the cargo area, the doors, and the headliner will help a good bit. The tar or rubber matting dampens vibration, and the foams actually dampen road noise, so you'd need both to do a good job. Anything that is actually rattling will need to be fixed the right way, tightened up or taped/glued, to stop the rattle.
