Results 1 to 3 of 3
This is a discussion on Climate control System and clock lights within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Hello everyone, does anyone know if it is normal for the lights in the center of each of the three ...
    Mar 2007
    Hello everyone, does anyone know if it is normal for the lights in the center of each of the three climate control dials to only light up barely visible enough to see in daylight conditions. It is hard to see if the AC is on or not. Also the clock seems to be very dimly lit and hard to see in the daytime, is there a way to adjust the brightness of these? I have a brand new 07 STI (not the limeted version).
    Registered User Slider's Avatar
    Mar 2007
    Fredericksburg, VA
    Isn't there like a gauge cluster light adjustment knob somewhere? Every car i have been in has a knob somewhere to turn the brightness of the clock, gauges and AC lights up or down.
    Semper Fi
    The Hawk-Eye Alliance #62
    Military Militia #11
    2007 WRX TR, WR Blue: Stg 2
    Registered User Richie03's Avatar
    Feb 2003
    PA
    Quote Originally Posted by j_rc_heliman View Post
    If you have your headlights or parking lights on the interior lights (such as the clock, climate control) will dim because less light is needed for them to be visible at night. So you can either turn off your headlights or parking lights. Or you can adjust your interior lights dimmer.
